Mike Green started a project called "Mike's OS" which later became the basis for his femtoBASIC, which is a Propeller-based clone of Tandy Color Computer BASIC. You see, instead of an "operating system" as we think of it today, a lot of the old 8 bit computers came with BASIC on a ROM, and that was both a programming tool and an operating system, because you could manage files and launch other programs and even run hardware "drivers" all from the BASIC prompt.
You could attach a screen and keyboard to a Propeller, and run femtoBASIC on it, and have something similar in capability to an old-school 8 bit Tandy or Commodore. I built a Propeller- based computer in a suitcase this way, and I intend to make a smaller version too.
LOOKDOWN ThisThread, [noparse][[/noparse]Your_?, My_?, Cool_Thing], looknum LOOKUP looknum, [noparse][[/noparse]1, 2, 3], subnum ON subnum GOTO Hope_this_helps, Thanks!, WOW!! END
I *think* that's the most current post with the OS...you might want to try further searches at the forums.
Yes, you could build a computer from a prop.. And run your own OS..
Oldbitcollector
Buttons . . . check. Dials . . . check. Switches . . . check. Little colored lights . . . check.
— Calvin, of 'Calvin and Hobbes.
Here's a link to the suitcase computer
Brian
uController.com - home of SpinStudio
