SLEEP - longer sleep periods
John Kauffman
SX/B SLEEP – longer sleep periods
I’d like advice on how to get SLEEP times on the order of
Here are my thoughts so far:
- 10 seconds
- 1 minute
- 10 minutes
- 1 hour
- External capacitor/resistor circuit that triggers a B pin for wakeup. Cheap and easy, but probably not very consistent times
- External 555 & its cap+resistor that triggers a B pin. Less fluctuation then just cap. Price still good. But 555 will draw power all the time.
- External real time chip (DS1302). Wake up SX every 2.3 seconds and compare last data collection time with current time. Expensive, but DS1302 may be on board anyhow for time stamp of data.
- There is a chip similar to DS1302 that has an alarm feature that could trigger a RB pin (DS1306). Again, probably only useful if project includes this chip anyway for time stamping data.
- Wake the SX every 2.3 seconds and keep a variable to count the number of wakes, then after x number of wakes collect data. A byte variable would get me up to 256*2.3 secs = about ten minutes (two bytes to get to 40 hours). This is an all software solution, but it seems a waste to use the current to wake up every 2.3 seconds for a few cycles just to increment the variable. Perhaps this uses less current then running any of the external solutions above.
- Combos. If want sample every 250 seconds, then do the wake every 2.3 sec and increment the variable, then after 100 increments, start checking the DS1302 on each wake and trigger the data collectin based on reading the DS1302 data.
Note that the watchdog timer is very inaccurate, so reading a DS1302 at every wake-up would keep things timed better.
Bean
My goal is to live forever...Or die trying.
www.hittconsulting.com
There are several methods to get the results you are looking for, but the best one depends on more specific detail of your requirements.
As each if the approaches has positives and negatives, and often these are at cross-purposes, specifically, what is the requirement and order of importance of:
Timing precision....
Lowest current...
Lowest cost....
Duration of program once running.....
Answering these will help set the "best" direction for your project. The more extreme your specs, the bigger the challenge.
I am working on a design that wakes once per second to a precision of a few tens of microseconds, draws an average of 50 microAmps of power so AA cells will run it for 3 years, and will operate outdoors at minus 40C for less than $10.00
So, the question is ...... what specs are important to you.
Cheers,
Peter (pjv)
I was hoping was that someone would say: "Hey John you fogrot about the x feature which allows you to multiple the sleep time by up to a thousand."
But that is OK. The solutions listed (and Bean's advice) will solve the rpoblem.
Look at my "magic 8-ball" code here http://forums.parallax.com/attachment.php?attachmentid=48918
See how the "wakeCnt" variable is used to do something after many watchdog wake-ups.
Bean.
