Basic circuit question
I have a basic circuit question.
If I have·four devices at 3 volts each; do I need to supply 3 volts or 12 volts to operate all the devices at the same time?
Thanks.
Post Edited (Bobot) : 10/7/2007 11:52:06 AM GMT
Thanks.
Serial connection:· power+ --> device--> device-->device-->device--> power negative.
Parallel connection:·· power+ --> device-->·power negative;··power+ --> device-->·power negative; repeat two more times.
I hope this helps!
Thank you very much. I do appreciate it.
Post Edited (Bobot) : 10/7/2007 11:58:08 AM GMT
It gets more complicated if it is something that is 'non-linear'. And some devices, like capacitors can work regardless of polarity, but other capacitors blow up if you use them backwards.
I guess I am trying to ask you for more detail, for safety's sake. The devil is in the details.
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
What do think?
I appreciate any input.
thanks.
