Getting my robot to stay in a specific area (Buried cable)
Hello! I have built and programmed my robot. I have built it from scratch and everything (kinda proud, since its my first project). Now i wounder how i can make it stay in a specific area. My plan is to bury a cable (12V or something going through), and get the robot to sence if its near this cable, and then turn. Now, im completely lost on how to do this "sensing"-part. Any ideas from someone that have done it?
Thanks in advance.
Thanks in advance.
QUOTE:
An invisible dog fence is also an option to inexpensively contain dogs in a very large area, often up to 25 acres. A wire is buried 3 inches underground and attached in a loop to the transmitter for the fencing system. The electric dog fence is completed with a receiver collar properly fitted to your dog. The collar then receives signals from the wire underground and warns and/or corrects your dog as it approaches the defined boundaries.
END
There is nothing about frequency or power level. I think should think a signal of a few milliwatts through a cable lying on the surface would do it. If you bury the cable you will have to increase the power output, of course.
Perhaps you could use a broad colored line to keep your bot corralled. Use an optical sensor with a glass or plastic filter "tuned" to that color to force the bot to turn away.
FWIW,
kenjj
Thanks.
Added: Mythbusters did a test about stealing power by putting a coil next to a power line, and it was supposedly enough to power a house. in actuality it was barely detectable. I think it will need to be quite the opposite, I think you'll want to power the line with a high voltage source. (low amperage). you are essentially making a Transformer (as I understand it) which would also mean that you would need to use AC Voltage.
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
Post Edited (Dgswaner) : 10/8/2007 8:56:11 PM GMT
Craig
"... one of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs." -
"If Python is executable pseudocode, then perl is executable line noise."
"The best accelerator available for a Mac is one that causes it to go at 9.81 m/s2."
"My software never has bugs. It just develops random features."
"Windows isn't a virus, viruses do something."
"Programmers are tools for converting caffeine into code."
"Enter any 11-digit prime number to continue."
