Can't Open Port
I have a Dell Inspiron 8200. When I try to load a program into a BS1 or BS2, it says it can't open the port. When I try the same thing on my wife's laptop everything works fine. Anyone run into an issue like this before. Windows says the port is working fine. The Stamp Editor is set to AUTO to select the ports. I have uninistalled and reinstalled the software. Any help appreciated.
Terry
Terry
Have Fun
TR
One big known problem is with cetrain SYNC progams like Microsoft Activesync or Palm Desktop. Thses programs run and keep the com port open all the time not allowing other programs to open them. This will be reported back as IN USE or NOT FOUND. If you are not using any sync programs look for other stuff that may be holding the port. Also, if your computer has builtin modem it is probably reporting on COM1. Look in your control panel under modems to see if one exists.
You don't say whether you are using serial or USB Stamp board or if you are using the Parallax USB-> serial converter. In any case if USB is in the picture anywhere make sure you download and install the current FTDI USB drivers. If you are using serial the suspect has to always start witht the cable connection from the Stamp board to the computer. If you are using a parallax supplied cable you are probably OK. If you are using some other combination make sure the cable is a straight through DCE->DTE cable. No gender benders or null modem. Also make sure the cables are completely seated in jacks. Some cables have nuts that protrude and do not allow the plug to be completely seated.
In notepad type in the following
FOR /L %%a IN (1,1,255) DO Mode COM%%a: >>c:\coms.txt
pause See results in c:\coms.txt file
Save as "commcheck.cmd"
double click on the file "commcheck.cmd" and it will run and create the "c:\coms.txt" file.
Open the coms.txt file and it will tell you if a port:
does not exists
·······Illegal device name - COM2
is in use
······ Device COM1 is not currently available.
or available.
··· ·Baud:··········· 9600
··· ·Parity:········· None
··· ·Data Bits:······ 8
··· ·Stop Bits:······ 1
··· ·Timeout:········ ON
··· ·XON/XOFF:······· OFF
··· ·CTS handshaking: OFF
··· ·DSR handshaking: OFF
··· ·DSR sensitivity: OFF
··· ·DTR circuit:···· OFF
··· ·RTS circuit:···· OFF
Have Fun
TR
Post Edited (TechnoRobbo) : 10/7/2007 8:46:50 PM GMT
Illegal device name - COM3
Status for device COM4:
Baud: 115200
Parity: None
Data Bits: 8
Stop Bits: 2
Timeout: OFF
XON/XOFF: OFF
DTR circuit: OFF
RTS circuit: OFF
When I look in Device Manager, it doesn't show a COM4. It only shows a COM1 and says it is working fine, however I can't access it. Any ideas why COM4 doesn't show in device manager? Thanks.
Terry
