Are SX register values lost after sleeping and wake-up? — Parallax Forums
william chanwilliam chan Posts: 1,326
edited 2007-10-06 17:24 in General Discussion
Let's say we assign some values to a few registers in bank 7.
Then we make the SX go to sleep to save power.
When the SX wakes up, will the values in the registers be lost?
www.fd.com.my
www.mercedes.com.my
  • JonnyMacJonnyMac Posts: 9,447
    edited 2007-10-06 13:47
    Couldn't you just write a simple test program to verify that? Or check the docs?...
  • BeanBean Posts: 8,129
    edited 2007-10-06 14:23
    william,
    When the SX wakes up it starts executing code from the beginning again. It does NOT continue with the next command after the SLEEP command.
    Read this application note: http://www.parallax.com/dl/appnt/sx/An18Reset.pdf
    Also if you are using SX/B make sure you specify NOSTARTUP on the PROGRAM line or else the compiler WILL clear all variables after you wake-up from sleep.
    Then you can just use:
    · IF PD = 1 THEN ' Check "Power Down" flag
    ··· ' Power Up Code
    · ELSE
    ··· ' Wake-up Code here
    · ENDIF
    Bean.
    My goal is to live forever...Or die trying.
    www.hittconsulting.com
    Post Edited (Bean (Hitt Consulting)) : 10/6/2007 2:58:17 PM GMT
  • pjvpjv Posts: 1,903
    Hi William;
    I agree with Jonny Mac, this is too easy to test by yourself.
    However, now that I'm on-line, I will answer that the RAM memory remains unaffected on wake-from-sleep.
    Cheers,
    Peter (pjv)
