difference between PING and INFRA-RED sensor
hello,
i am wandering on whats the difference between these 2,
i tried infra-red that comes with the boe-bot kit but (page 271 where there are 5 zones of distance) the value keeps flactuacting and not stable--is it normal--i mean if it is in zone 2,it will move to zone 1 and 3 quite often although i didnt shift my hand.
i wonder if PING is much more accurate(not sure wat is this supersonic device).
thank you
thank you
IR and Sonar work on different bands of the EM spectrum. Each has its pros and cons. IR can be affected by the ambient lighting conditions. It can also be affected by the reflectivity of the surface the light bounces from. Both can explain the readings you’re seeing. Skin isn’t really a good reflective surface anyway, especially when it comes to consistency.
Sonar doesn’t bounce well off software objects such as animals or people. It also requires a nearly perpendicular or curved surface to help ensure some waves are reflected back for detection. Depending on the angle of the surface the waves could be reflected away from the sensor. In most cases it works just fine in the manner used, but you should be aware of the potential in other uses. I hope this helps. Take care.
IR uses infrared light (which you cannot see). So, that light has to 'bounce' off an object and be 'seen' by the IR-Sensor. The "distance zones" in this case is a clever hack, that uses the amount of light reflected as some indicating of 'range'. But this is really inaccurate -- it's much better as a collision avoidance method than actually measuring distance.
The Ping sensor uses high-frequency sound (which you cannot hear). Now, sound travels MUCH more slowly than light. So measuring the time-delay between when the sound is started, and when the reciever hears the echo of the sound, is much more easily done, and is appropriate for repeatable accurate distance measures (up to a few feet).
"Super-sonic" usually refers to something like an airplane moving faster than the speed of sound. "Ultra-sonic" refers to a sound-wave tone at a frequency higher than you can hear. The Ping sensor uses Ultrasonic sound.
ukkhs, sorry mistaken to refer ping as a supersonic device..really embarassing..haha. actually i want either one of these sensors to be mounted on my pan and tilt with 2 servos(2 degrees of freedom).
i want this pan and tilt to move up and down ,left and right according the movement of my hand.i was cosidering these two sensors to detect my hand or body the best.
what do you think is the most suitable guys?
thank you in advance
probably i will start with infra-red cos thats what i have right now---if the performance is acceptable then i will stick to that one.
http://en.wikipedia.org/wiki/Sensor_fusion
