Hall Effect Sensor — Parallax Forums
Hall Effect Sensor
Jared5755Jared5755 Posts: 26
edited 2007-10-05 18:43 in General Discussion
I'm looking for a hall effect sensor I can directly connect to a microcontroller like the Stamp.· So, the output will have to be +5v and 0v.· I've searched all over and the only one I can find isn't in stock anywhere, so I'm guessing it's not manufactured anymore.·
Oh yeah, it would need to be a larger package (not one of those tiny things that are hard to solder).
I spent a lot of time looking on google, so thanks a lot for helping me.
Jared
  • Beau SchwabeBeau Schwabe Posts: 6,573
    edited 2007-10-05 05:35
    How about this?
    http://www.parallax.com/detail.asp?product_id=605-00005
    Beau Schwabe
    IC Layout Engineer
  • Bruce BatesBruce Bates Posts: 3,045
    edited 2007-10-05 12:29
    Jared -
    Finding a supplier for a given type of Hall Effect sensor is fairly trivial. However, you need to know what kind of Hall Effect sensor you need. Merely based on what you've said so far, I suspect you may be looking for a Hall Effect "switch". These will output a 1 in the presense of a magnetic field, and a 0 in the absense of such a field. Even if that is the case, more information may be required to find a Hall Effect switch suitable for your particular application.
    If you indicate the application or purpose for this sensor we may be able to provide additional feedback.
    Other types have differing outputs (see below) and respond to differing magnetic·stimuli (also see below):
    General Information - Hall Effect Sensors
    Type of Hall Effect Output Signals:
    analog or digital
    ratiometric (a la a sine-cosine voltage output)
    PWM
    PBASIC PULSIN suitable
    others are available
    Magnetic Stimuli:
    Bipolar
    Unipolar
    Omni-polar
    Gauss range sensitive - with or without user set-points
    Input/Output Options:
    Latching output
    Non-latching output
    Speed/Direction sensitive (dual element)
    Magnetic field sensitivity
    I usually look to Allegro Micro for my Hall Effect sensor needs. Here is a link to their Hall Effect sensors:
    http://www.allegromicro.com/en/Products/Categories/Sensors/index.asp
    They also have a rather liberal samples policy, so long as it isn't abused.
    Bruce Bates
  • Jared5755Jared5755 Posts: 26
    Thanks a lot.· I've never heard of "Hall Effect Switch", but that's exactly what I'm looking for.
    It looks like the one on the parallax site will work just fine.
    Thanks a lot.
    Jared
