Serial Comms with SX48 1 wire or two
I have serial comms between a prop and an SX48 so I'm not sure which forum to post this in.
Basically, I have a 2 wire communication working perfectly... I'm using FullDuplexSerial on the prop and standard Serin/Serout on the sx48 using sx/b.
Any how I wanted to convert this to a single wire. So I just chose the same pin for Serial Input and Output on both Micros... Now I can send from the Prop and it recieves well on the sx48, but I send from the SX to the prop... Any Ideas?
Eric
Eric
The FullDuplexSerial routines have a mode parameter. If you set the mode to be %1100, this will set open-drain mode and the transmit routine will throw away a received character for each one transmitted (since the receiver is always active it will receive all transmitted characters). Open drain mode will set the I/O to input instead of driving the I/O pin high. It will drive the I/O pin low, but you'll need a pull-up resistor to provide the high logic level. The receive routine will be able to receive between transmitted characters which is what you want.
Try just changing the mode parameter and adding the pull-up if you don't already have it.
I'm hoping not as I want the SX (Slave) side to be independant of the (Master).
Eric
In any event the SX is controlling a motor driver board that I am also designing (Yeah I know there are a ton of them out there) but none that I made... It's a total learning experience for me. [noparse]:)[/noparse] Thanks for you insight.
Eric
Post Edited (SailerMan) : 10/4/2007 6:26:12 PM GMT
The simplest set of rules is that one side of the conversation always initiates:
SX: Talk to me (are you still there?)
Prop: What do you want to know?
SX: Send me a packet
Prop: Here it is
SX: OK, I got it
SX: Nothing really, just checking
I was getting unusual numbers on the propeller... I looked at the scope and the bit pattern looked a little poor and it was being sent a little too early it seems that this small delay has got it working.. I don't know why. Hmm.
The SX was sending %1101_0000 but the Prop was receiving %0110_1000. I'll have to look at this in more detail.
Eric
Post Edited (deSilva) : 10/5/2007 6:13:03 PM GMT
V24 RS232 bidirectional bi-directional oneline onewire FullDuplexSerialbidirectional bidirectionalfullduplexserial oneiopin for bothdirections
V24bidrectional serialbidirectional FDSbidirectional singlewire singleline V24singlewire V24onewire RS232singlewire RS232onewire
Stefan
