lol, I've got a ready to run package....or will, when i put some motors and drivers back on it.
i am in the process of upgrading from a 16" x 20" cnc router to a 27.5" x 60 " , i've swiped my motors and drive controllers off the old machine to finish the new.
the only problem is when i put some new controllers and motors on it, i'll probally want around 6-800 for it. and its heavy, not something you would want to ship.
but parts man is right, building them is soo much fun, first you use woodworking and metal skills, then electronic, then if you use turbocnc , a lil computer, then you get to learn cad and Gcode. for a handyman, its like a trialthon.
dan
by the way, using Pminmo's driver boards, it· should be simple to hook up a prop protoboard to them along with a sd card reader... just need a lil program to read g-code and sennd out the right pulses, one for direction, one for step for each axis
dan
Post Edited (Sawmiller) : 10/4/2007 7:10:21 PM GMT
I was looking at some cnc related stuff on youtube and saw some references to the new linear motors. These things are amazing, and just think, no mechanical parts such as lead screws or bearings, etc. to make a mill. The speed and accuracy ( 5 micron ) are a bigger bonus. I would imagine them to be rather expensive at this time, hopefully in the near future they will be affordable.
I built mine from wood and skateboard bearings. Even made a·Penguin with it. These things are cheap to make if you shop around for motors and controllers (couple hundred bucks) The rest can be found at Menards or·Home Depot.
I wish they offered a "ready-to-run" package though.
Bean.
My goal is to live forever...Or die trying.
www.hittconsulting.com
Brian
uController.com - home of SpinStudio
i like looking at http://buildyourcnc.com/default.aspx·as a simple way to build your machine.
dan
dan
He will custom build one for you. the price is dependant on the travel distances. and the machine is made from plate aluminum.
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
www.baldormotion.com/products/linearproducts/lss.asp
