300ma LED Strobe Light
Good day to all!
I want to build a strobe light of sorts using a single LED to start and adding more as I learn.· Then maybe progressing to PWM output.
1. Using logic level N-Channel MOSFETS (2n7000), what would be a good circuit to use to:
·· A. Protect the port on the propeller.
·· B. Provide the proper forward current to the LED.
2. What might be a good way to "Strobe" the LED in SPIN?
·· A. Programmable on time.
·· B. Programmable off time.
I've looked at the following circuit:
I arrive at the 6.8ohm resistor using: .3ma / ((3.2VDC * 1)- 5VDC)
The 1k resistor is something I've seen using the PIC chip.·
SPIN code idea
{Obvious code Here}
repeat
··· !outa[noparse][[/noparse]Pin]······· 'toggle the port
··· waitcnt(clkfreq / 1000 * DelayMS2 + cnt)···· 'wait using an independent·"on time"
··· waitcnt(clkfreq / 1000 * DelayMS + cnt)····· 'wait using an independent·"off time"
SPIN code idea
Thank you for your indulgence!
Post Edited (Moonwizard) : 10/4/2007 3:07:02 AM GMT
-----------LED---6.8ohm------5VDC
pplr mosfet |
| | Drain |
P2 |---1k--------|Gate |
| | Source |
GND
SPIN code idea
{Obvious code Here}
repeat
SPIN code idea
300mA is not so much you could not use any standard bipolar power transistor (beta = 30, so the Prop has to drive with 10 mA, needing a base resistor of 220 to 330 Ohms)...
BTW: The forward voltage of a 300mA LED should be much more than 1V8...
Post Edited (deSilva) : 10/4/2007 3:05:10 AM GMT
