basic servo control question — Parallax Forums
ziggyramaziggyrama Posts: 1
edited 2007-10-04 02:13 in BASIC Stamp
Hi, I am sure this has been addressed before, but I haven’t had any luck finding an answer. I am trying to control a single servo and move it slowly from a stationary center position to a 90 degree position and hold it using a BS2 and an unmodified servo. I am using a standard FOR NEXT LOOP to move it, but cannot figure out how to leave the loop and keep the servo at 1250 once it reaches the final point. The servo simply pans back and forth between the two positions. I've tried using an IF statement to leave the loop, but it doesn't seem to work. Any help would be appreciated.
for x = 750 to 1250 STEP 25
PULSEOUT 1,x
PAUSE 20
NEXT
    edited 2007-10-03 19:21
    ServoPos VAR WORD
    X VAR WORD
    FOR x = 750 to 1250 step 25
    ServoPos = x
    GOSUB RefreshServo
    NEXT
    RefreshForever: ' Infinite loop, holding servo position...
    GOSUB RefreshServo
    GOTO RefreshForever
    END
    RefreshServo:
    PULSOUT 1, ServoPos
    Pause 20
    RETURN
  • LilDiLilDi Posts: 229
    With a BS2, each PULSOUT unit is 2 micro seconds. A servo pulse width is from 1.0 milliseconds to 2.0 milliseconds.
    Doing the math, that means the code for moving the servo should be
    FOR x=500 to 1000 step 25
    Center position is PULSOUT 1,750
