Vga dac
I have noticed that the resistor ladder Composite/VGA DACs in the prop manual and in the protoboard seem to be able to output 3.3v assuming that all 3 bits are set to 1.
from what i have learnt so far, the max voltage into a vga monitor signal is supposed to be 0.7v peak to peak.
would, accidentally pulling a signal to over 0.7v be damaging, or is there some kind of protection circuitry in modern monitors?
also, what are the voltage levels for TV composite?
Holy parallel processing, Batman!
Post Edited (Mr Crowley) : 10/2/2007 9:04:06 PM GMT
From my best guess, the following happens when connected to the monitor:
1/(1/470 + 1/420) = 221.8 ohms (both DAC resistors in parallel)
(75 / (221.8 + 75)) * 3.3 = 0.834 V across the 75 ohm resistor
So, the monitor would be *seeing* a 0.834 V signal.
Post Edited (Mr Crowley) : 10/2/2007 9:12:55 PM GMT
Paul Baker
Done, sry bout that.
Post Edited (Mr Crowley) : 10/3/2007 1:42:27 PM GMT
In fact TVs are by no way such touchy. I soldered some video interfaces during the last weeks for my class and took the values out of my standard box: 1k, 470R, 220R
This is absolutely fine!
Edit: I even used a 7 resistor SIL package @1k once, shorting 2 and 4 of the resistors for the bit1 and bit2 output. This looks very professional, but is by no means practical and takes more space on a small perf board.
Post Edited (deSilva) : 10/2/2007 9:56:46 PM GMT
