Propeller Tool v1.05.7 COM PORT LOCKUPS STILL
I know others had the problem of the Propeller Tool iterating through COM ports and when it finds a Bluetooth COM Port that doesn't have and endpoint, it LOCKS-UP.· I have to END-TASK to get it to stop, which means I have to re-launch and re-open all of my files.· I have wasted SOO MUCH TIME because of this BUG.· If I forget to plug the PropPlug into my protoboard before hitting Compile, I'm hosed, Every Time.
I write lots of windows apps and I know it is not difficult to allow us to SPECIFY a COM port to use instead of the Propeller Tool needing to check every COM port to find the·Propeller.· It's a big waste of time.· Albeit handy for the newbee to get started.· It REALLY needs to be an OPTION.· Please.· I love the propeller and everything about the Propeller Tool.· Except This COM Port issue.· I was really hoping such a simple option would be available on this new version.
Just let us type a COM Port # in.· When you open the Port, you pass COM 1 through COM 9 as "COM1"..."COM9" to the port name, then anything over COM9 has a windows port name of [url=]\\.\COM10[/url] and so on.· In case that was the hangup in implementing this option.
If it doesn't happen to you, then obviously it's not a big concern, to you.· But for those of us with built-in bluetooth and the computer assigns a bazillion (give or take) COM ports for bluetooth devices that don't exists, it's really really irritation.
I already sued for that and as now about that to hear nothing.
My unique decision is moving of numeration of COM.
Operates but not in all of situations.
My Propeller Tool made off find of the COM.
And only program which operates in that, to program Propeller of this Aribas Propterminal but only to RAM.
http://forums.parallax.com/showthread.php?p=675860
Nothing is impossible, there are only different degrees of difficulty.
Sapieha
Everything works just fine then. This does not even require a reboot or anything. Are you guys running blue tooth devices while using the Propeller tool? If so, what are they?
When it's time to do something else, turn the radio back on.
I run blue tooth devices pararel with Tools.
And in my system I mast have it RUN always.
Ps.
So as though to someone to say Doors are corrupt, drop in by a window.
Sapieha
Post Edited (Sapieha) : 10/2/2007 7:41:37 PM GMT
Paul Baker
Thanks for replay.
It was well att hear. For all
Sapieha
But, just for kicks. Bluetooth is now OFF. I launch Prop Tool, hit F10. Checking COM6 (Not Responding). Locked up. Windows Device Manger does not show I have a COM6 at all. So it's not just related to Bluetooth apparently.
But thats OKAY. Because they are going to fix it.
Grrr, mouse no workey, must turn bluetooth back on now.
Paul Baker
This problem has really reared it's ugly head since there were many complaints about ports not showing up at all.· Turns out, they have drivers that done expose an interface (like they should be doing) and after testing, with this customers on this forum, all reported good things, so we rolled those changes in and released.
Either way, we'll make it right and give you the options you need very soon.
--Jeff Martin
· Sr. Software Engineer
· Parallax, Inc.
The better solution is the PropUp-Hack:
http://forums.parallax.com/showthread.php?p=665707
Andy
It is not problem.
If I not have PropTerminal I have not capablities to program Propeller.
Sapieha
I have not tried PropTerminal (PropUp)...
And now I have. Very nice and simple. If you give it the right port, it works, if you don't, it won't. That's the way it should be. Makes me want to hookup more propellers to the PC now.
I work with real-time signal processing so I have a tendency to notice wasted Seconds.· Have you ever been on the phone with a Customer, trying to access their account information on the computer, and for whatever reason, this time there is a 20 second delay before the data is returned?··
Maybe I should have just banked the seconds I spent writing this and saved them for the times I miss-hit Ctrl-F11.·
Awww, I just wasted more seconds adding Emoticons!·
