SX Protoboard Supply Voltage
VonSzarvas
Perhaps an insanely silly question, but I am really curious...
The proto boards are marked 6-9v supply voltage. The datasheet for the LM2940 states up to 26v is ok!
Would I be safe to use an 11-13v supply?
Perhaps just the 47uf cap on the 5v side should be lowered to a 10uf? That is what I have seen on other example circuits...
I am really tempted to try, but don't wish to smoke a protoboard unnecessarily!
Thank you for any advice.
100mA or so should be okay.
Don't bother changing the cap, that won't make any difference.
Bean.
I know what I know, don't confuse me with the facts...
www.hittconsulting.com
So that would mean the issue is the heat created by the voltage difference and power consumption? I can appreciate some projects using juicy servos etc.. may rely on more power, so the 6-9v plays it safe.
100mA would keep the power consumption (5v x 0.1a = 1/2 watt) manageable up to about 85 degrees (according to the datasheet).
-- But the important factor is the PD (Power Dissipation) calculated as voltage dropped across the regulator multipled by current consumed.
-- Ie. (Vin - Vout) * Io = (13 - 5) * 100 mA = 0.8watts.
so it seems I can do this well within spec, as I am pulling about max 60ma at the moment !
Thank you Bean.
A few more years I may develop the confidence to trust what I read and know without careful scrutiny!!
Edited: To include Beans correction below, so as not to mislead future readers.
Post Edited (Maxwin) : 10/2/2007 4:15:23 PM GMT
The power disapation with 26V input and drawing 100mA = (26-5) *0.1 = 2.1 Watts of heat.
I'd stay below 1 watt of heat to be safe.
Bean.
