solder : Acid core
Dose using an acid core solder eat your tip on the soldering iron? I think I used the wrong solder.
I do work for food!
skype me: quispqix
KC0LGV
Echolink: 184783
users.adelphia.net/~quispqix
I do work for food!
skype me: quispqix
KC0LGV
Echolink: 184783
·Here is a link that should help you
http://www.howardelectronics.com/·This is there home page
They have a solder that called·No Clean very good stuff
I·use it and works very well and it also has a flux
·http://www.howardelectronics.com/amtech/NCsolder.html·
Or go to Radio Shack and buy the solder the 60/40 It do have flux in it yes
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 10/2/2007 2:22:53 AM GMT
it could be that my tip needs replacing. But I doubt that so I think It is 'not right solder' I take the soldering iron tip off occasionaly because the the pencil and cord were expensive to replace a WELLER EC4001 and WELLER EC1301 tip. I think it is acid because what is left of the tip seems to be getting smaller in less than 1 hour @ 500~F
I do work for food!
skype me: quispqix
KC0LGV
Echolink: 184783
While the acid-core solder may 'eat the tip' of your solder iron, it also will continue to eat at electrical connections long after you have soldered them. That is not a good thing as the oxide creates electrical resistance in unwanted places.
Why do they make acid core solder? If you are soldering things like gavanized rain gutters or other hardware, the weathering and layers of corrosion can be quite thick, so a stronger cleaner [noparse][[/noparse]it the form of acid] is needed to get a good mechanical connection. If the metal isn't clean, the solder just won't stick.
Usually you can smell the difference between acid and rosin core. Acid is very 'sour' and rosin is more like 'pine tree scent'.
There is also 'coreless' solder without odor. You can use this with a liquid or paste flux that brush on. In fact that was the traditional way to solder until someone figured out a way to put the flux material inside the solder. The liquid flux is easier to wash away after you complete your project.
Also, your solder iron tip can wear out from overheating over long periods of time. You can either replace or reshape the tip with a file. If you reshape, you have to also re-tin the tip [noparse][[/noparse]cover it with a layer of solder] so that solder will stick to it.
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
"... one of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs." -
"If Python is executable pseudocode, then perl is executable line noise."
"The best accelerator available for a Mac is one that causes it to go at 9.81 m/s2."
"My software never has bugs. It just develops random features."
"Windows isn't a virus, viruses do something."
"Programmers are tools for converting caffeine into code."
"Enter any 11-digit prime number to continue."
No clean solders/fluxes are typically used for hobbyist electronics as the activated flux leaves a barely noticeable residue that can be left. Keep in mind though, even no-clean flux is corrosive if it has not reached the activation temperature. This was recently discussed in SMT magazine (a PCB manufacturing trade mag)
Solder with silver content is a heavily debated topic in the hobbyist world, especially amateur radio. The physics and chemistry involved in a plain old solder joint is rather amazing and so it lends to many opinions. The solder with 2% silver, generically referred to as "silver solder", is preferred by many in the RF world but has no real effects on common analog and digital circuits.
Long story short: Use good old fashioned 63Sn/37Pb, No Clean Flux Cored solder. Clean off any excess flux residue with IPA Alcohol or spray flux remover. Use a good tip, the right size for the job, and keep it clean/tinned (always tin your tip when putting it in the stand and when putting it away) That sounds elementary, but I have proven tip life simply by those steps.
ps I have been in PCB manufacturing for 16 years
~~ dRu ~~
Generally, silver 'electronics' grade solder is un-necessary and a gimmic.
Sure, silver and gold conduct electricity better that copper or aluminum. But if you really consider how larger your wire cross-section is in relation to how little is gained by the change in alloy, it is trivial.
If you were to be soldering wires from silicon chips to the IC pin outs, maybe you would need such silver solder and gold wires.
There is also a 'higher temperature' silver solder that is used in jewelry making and places where the usually lead/tin solder doesn't make a strong mechanical joint. It is sometimes used for modern plumbing to avoid lead in drinking water.
But the electronics myth continues that silver must always be better because silver wire is also used in high frequency wiring - gigahertz. In such applications [noparse][[/noparse]like radar], that little bit extra does count. So you might be using silver wire and electronics grade silver solder.
Nowaday, we also have the ROHS solder to contend with. But again, it is a tiny shift in conductance and requires a bit higher temperature. Not much to worry about.
Save that acid cord solder for when you have to repair a frozen copper water pipe. Of course, you now may be wondering if you want to put any more lead into the construction of your water pipes. Newer homes are using silver solder to avoid the issue. Personally I have given up worrying about the tiny amounts of lead in my copper water pipes. And I don't really worry about the tiny amount of mercury in my silver amalgam dental fillings. I seemed to have survived both.
http://www.indium.com/products/sorted_by_temp.pdf
Flux
http://www.indium.com/products/solderkits/fluxselectorkit.php
SJW
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
http://www.inlandcraft.com/Uguides/tipcare.htm
FYI: If my Weller tip is ignored for a while, I usually start my work session with quick session on the sal-ammoniac tinning block discussed in the above link.
pw
There's nothing like a new idea and a warm soldering iron.
Paul Baker
I am gald that you point this out
Lead free solder oxidizes solder tip much faster than lead solder, it can get so bad that retinning is necessary.
The higher the temp the faster it seam to happen
I thought that is was just me that was see this
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 10/3/2007 5:12:33 PM GMT
