Useing TRIACs with the prop?
I just bought three of these https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=160231&pa=160231PS·I have never used TRIACs before so any help would be great. ·· Here is what I am trying to do, I need to dim a 120 volt ac / 60 Hz lamp how would I hook up the TRIAC? What safety precautions do I need to take?· And last of all what would i need to do code wise?
My computer, http://forums.parallax.com/showthread.php?p=630466
http://www.fairchildsemi.com/ds/MO/MOC3031-M.pdf
The datasheet says: "Isolated packages are offered with internal construction, having
the case or mounting tab electrically isolated from the semiconductor
chip."
This just means what it says... You can safely screw it to any place.. more or less...
http://www.vellemanusa.com/us/enu/product/view/?id=350504
