Time difference in ms
Hello all -
············I wast to display the difference in time in (milliseconds)·between a pin going high and low
have you any suggestions ?
This assumes that the pin is already set as an input and is low when the routine is executed.
How you display the value this returns will depend on what kind of display you want to use.
