Extending a PIR module to 35-70 feet away with phone cable. Can this be done?
I have 5 PIR modules (Motion sensors).
I'm trying to build an elaborate home alarm system with motion sensors both inside and out. I have seen the 14" Servo motor/LCD cable that looks as if it would fit the PIR·module. I would like to know if I adapted it to telephone cable, would it work over a 30-70' run of cable? Even if I power the sensor from the central base, not at the sensor? I guess I'm woried about the resistance and potential capacitance of the cable. I'm no electronic engineer and don't know if these effects will come into play or not.
The BasicStamp would act as a data collector and repeater. You might even use a BS1, if you want both the lowest cost and low power consumption. For RS-232 you should use a MAX232 or an ultra low power version. Maxim also has ultra low power RS-422/485 tranceivers. Anything not ultra low power will quickly consume batteries.
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
... I'm not recommending this store - I just pulled it out of a list -·· http://www.homesecuritystore.com/ezStore123/DTProductList.asp?p=2_1_1_1_0_0_14
· ... but a cheap detector sells for $17.50.· wireless models are available, too.
... and, YES !··150 feet of common telephone wire will·allow commercial PIR sensors to operate normally.· Typically, they operate on twelve volts sent over two conductors.···· (and like Kramer, I think it's a stretch to expect it to work with Parallax's modules...)
·tommy
Post Edited (tommy) : 10/1/2007 3:19:38 PM GMT
@Tommy, That link is exactly what I neded!!· I would·prefer to buy·a self install security kit but I went to several retail outlets and couldnt find any. They used to be popular but it seems like none of the big home centers carry them.· Don't know why I didn't find them online when I looked!!!· ·That link has everything I need.··· I was only considering building it from the Basic stamp because I already had 5 parallax·PIR modules.··
Thanks Again!!!
