Bell for a tiny dog — Parallax Forums
Bell for a tiny dog
peterzpeterz Posts: 59
edited 2007-09-30 15:55 in General Discussion
I would like to have something like a passive(or almost) bell for a tiny dog.
The idea·is that·I want to hear·him approaching but·I don't want the bell ringing all the time, just when the dog is near to me, and I better if the bell ring on me, instead of ringing on the dog.
The perfect solution would be to have something passive on the dog, like a RFID, but I don't know whether this would be a suitable solution, because,·suppose the dog is·5 feet·away, would it work ? BTW, does the size of the RFID tag matter?
If an RFID is not a solution, which alternatives are there?
    edited 2007-09-30 13:51
    RFID doesn't have the range to do what you want (at least not with the units available from Parallax). How about if you wear an IR beacon that puts out a pulse of modulated IR light a couple of times a second. The dog collar would have an IR detector and a microcontroller which would verify the IR signal and sound a tone through a piezo speaker. If you want the speaker on you, you could put the IR beacon on the dog.
  • D FaustD Faust Posts: 608
    edited 2007-09-30 14:27
    FYI if you don't want to use an uController of the emmiter you can make one with a 555 timer IC.· I think there is a schematic in the IR remote book.· You might be able to eliminate the the IR detector ucontroller by having the detector pull the base of a PNP transistor low when it senses the IR.· You could use a piezo buzzer with the built in resonator things (not·the one·with the boe-bot)·so that· when you supply power to it through the transistor it beeps.· You would probably add a switch to each of these devices so that you could turn the buzzer off.
    LOOKDOWN ThisThread, [noparse][[/noparse]Your_?, My_?, Cool_Thing], looknum
    LOOKUP looknum, [noparse][[/noparse]1, 2, 3], subnum
    ON subnum GOTO Hope_this_helps, Thanks!, WOW!!
    END
  • peterzpeterz Posts: 59
    edited 2007-09-30 14:49
    The IR method would not work as it would require a straight line of sight. If I wear my IR emitter in my front it would not work when I am looking backwards. I would need something that works in any direction.
    edited 2007-09-30 15:07
    peterz,
    I was imagining several IR LEDs driven by one 555 timer or several pins of a microcontroller so that they pointed in several directions. In addition, I was assuming that there'd be some reflection so the room would be filled for some distance around with modulated IR at an intensity enough to activate the detector.
    edited 2007-09-30 15:18
    peterz said...
    I want to hear·him approaching...
    Assassin Chihuahuas: If they see you before you see them --then·you're toast.
    edited 2007-09-30 15:29
    What if you use RF.· It would be more expensive, but it would work without line of sight.· Unless this is a killer dog situation, RF is probably overkill.
    END
    This is probably the kind of thing you're after, except repurposed to warn of proximity, rather than a lack of proximity. I believe there are similar devices available to prevent theft of laptop computers, cellphones, etc.
