DS1307 Pullups
I am trying to design a new module which uses Prop Pins 0-2 and 4-7.· One of the items on the module is a DS1307.· I normally take the SDA and SCL pullups to my 3.3VDC source.· Since Pin 3 is available, is there any reason I can not tie the two pullups to Pin 3 and just keep that pin high.· it would certainly tidy up the layout.
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
However 10k is just a conventional value used out of convenience. Any value between 3k3 and 33k should work, and some even say 1k to 100k. So just pick a higher value (47k?) and the current drain will be negligeable.
Post Edited (deSilva) : 9/30/2007 5:14:13 PM GMT
