Any helpful hints for transfering toner to PCB?
I swear to god I must have tried this 20 times in the last 2 days. I have used Staples Photo Paper, wax paper, magazine paper, label sheet paper, and just about everything else. What am I doing wrong??? I print the design on the paper, place it on the cleaned/sandpapered board (although I've tried it without) and press the iron on it and press for 30 seconds. I then try and move it around a bit, but even if it doesn't slip and smudge the design (which happens with everything except the photo paper) it doesn't transfer all the way, and I end up with half the board non transferred at all, and the other half so well transferred that it takes a miracle to clean it off to try again. Seriously this is driving me crazy.
And then the fact that this is a DIP propeller board means that I'll have to drill upwards of 120 holes total. So I need a reliable, repeatable process for doing this that will let me try again in case I screw up somewhere in the loooong process. I would love to just order the damn boards, but I can't afford to make a mistake in the layout if I do at like $20 for a small board. Or I could wait 3+ weeks to have it done through batchPCB or something.
Do you people seriously have any success with this? I can't fathom how anyone gets predictable results.
Oh, and to top it all off my boards are double sided. Fantastic.
A frustrated noob
A frustrated noob
Normally I wouldn't use sandpaper to clean the board - the copper is only .0014 inch thick. Steel wool and nail polish remover and 15-30 minutes of scrubbing should get the image off the board.
Also file down the top edges of the board in case there are burrs where the copper is bent up slightly from the cutting process. These can prevent the iron from making full contact, especially near the edges.
I clean with 400 or 600 grit wet sanding followed by an abrasive cleanser like Ajax or Comet, then water rinse. If you don't get ridiculously aggressive, you will lose very little copper from the sanding. Scotchbrite type pads instead of sandpaper also work well.
After transfer use a solvent like lacquer thinner, MEK or acetone to remove the toner. If you use nail polish remover, be sure to wash the board afterwards since they contain oils and moisturizers in addition to the solvent, which can leave residue that impairs solderability (you should always clean the board before soldering anyway).
Personally, unless it's a very simple board that is needed "right now", I would go with a commercial supplier.
- Rick
It's expensive, but it's the best I've ever used. After you laminate it to the PCB, you put the board (and paper) in the sink filled with water and the paper literally floats off the board. There is absolutely NO toner left on the paper. I have done 0.010" lines with 0.010" spacing with no problems.
Bean.
I know what I know, don't confuse me with the facts...
www.hittconsulting.com
Then wash the residue off the copper with mineral spirits, laquer thinner, acetone, or - if nothing else - rubbing alcohol. The rubbing alcohol is a bit corrosive, but it and acetone are least harmful to one's health and liver function.
All that might get the toner to attach more evenly.
Pulsar is a whole system and relies on good outcome to keep its customers. All the DIY tricks are cheaper, but more varied in result. I personally prefer photo emulsion and printing a transparency on an HPInkJet [noparse][[/noparse]the only one with the right ink for dense black transparencies].
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
There's nothing like a new idea and a warm soldering iron.
Also, make sure you are using a black laser. I have a color laser at home and it does not work since color lasers seem to use a higher temperature toner. I believe they also use a different kind of plastic since it looks different when printed on paper.
Harrison
Maybe I should just try the photo emulsion method, since it seems more repeatable and it's not much more expensive for coated boards.
Either that, or I'll try the pulsar system. Has anyone had any experience using a laminator to apply the necessary heat/pressure to the board? What about the "Toner Applicator" that pulsar sells?
Thanks again
I remember I tried to create a pcb using the toner transfer method using my color laser at home (it's a xerox/dell color laser) and I was not able to get anything to transfer. I even sent the photo paper through 4 times to get more toner on the paper. I gave up and just went back to my b/w laser.
Harrison
Post Edited (Harrison.) : 9/30/2007 3:38:01 AM GMT
Second...I find that a single sheet of regular paper towel between the iron and the transfer works to give you more even heat to the transfer, and also provides a coushion so the iron does not melt or scorch the transfer.· You will notice that the iron will "slid" easier over the paper towel as it heats up the transfer itself.
Deno
Twisted Pair....
If I could have back all of the time I wasted on toner transfer... [noparse]:)[/noparse]
Eric
