Battery question 7.2v 2000 mAh
I am designing a bot around a BOE and BS2. I'm using 4 servos, and using several sensors, an LCD, etc. I wanted to use a battery that will last, so I picked up a Ni-Cd rechargeable battery pack at Radio Shack. It's rated at 7.2 V/2000 mAh - and was designed for RC cars.
If I plug this in my BOE, will I 'smoke' it?
An alternative (which I use) is 5 NiMH AA cells in series which yields 6.00-6.25. I happen to have a charger that's not fussy about the number of cells you charge at a time. I use the 4 cell holder that comes with the BoeBot and an extra single AA holder in series and mounted on the back of the chassis.
Post Edited (Mike Green) : 9/29/2007 4:37:24 AM GMT
I was also concerned about the current. One more question - if I were to connect two of those batteries in parallel - what about then? Would the voltage regulator on the BOE be able to handle the current? is there a better way to give your bot a longer runtime?
How did you counter the weight being on the back?· I tried loading the blade with 20 grams additonal weight but seemed like there was less weight on the axles and traction is a problem....
