PENGUIN ROBOT Display Graphics - the Code
Penguin Displays 5 Graphic Characters
penguin_display_graphics.bpx
Did you know there's a total of five secret hidden
graphic characters in Penguin robot? When Penguin was
first received, I wrote code to show all characters
that will display. Aside from numbers, five special
characters appeared!
were needed when writing code, but can say it's very
frequent. So this small code (6 lines plus 4 declarations)
was put together to display graphics and help as a
standalone program or as an add-on code for other
programs.
humanoido
I don't know how many times the graphic charactershumanoido said...
The strength of this code design is that a character
will continue to display even after the program has
ended, or when other code is running.
programs.
This program displays five graphics characters in succession, using their corresponding codes. The comments hold a reference in ascii showing what the characters look like. The program uses codes 10 through 14. To turn off the display, 15 is used. ' Orientation: face Penguin robot and read display ' __ ' 10 |__ ' ' __ ' 11 __| ' ' ' 12 |__| ' ' __ ' 13 |__ ' __ ' ' |__ ' 14 |__ ' ' ' 15 Off
humanoido
