Auto-Sampler Timing Circuit
I currently have an system that performs auto-sampling of plastic pellets. Every 30 seconds, a valve is opened for 5 seconds. This releases the pellets from the process line to a container.
I'm using a GE Fanuc PLC for this and would like to replace it. The cost of a PLC for such a simple circuit seems a bit ridiculous.
My question is: What type of microprocessor should I use, and, will the output handle the load of a approximately 1/2 amp?
Thank you,
Jerry
Thank you,
Jerry
See: www.efx-tek.com/topics/prop-1.html.
http://www.parallax.com/detail.asp?product_id=30064
Otherwise, any of the basic stamps will work, with some modifications. Maybe not even that much work.
Shawn Lowe
Maybe I should have waited to do that......
The attachment is an example of transistor control, replace the motor in the schematic with a relay.
Jeff T.
