Etchant Solution (Powder) Web Source — Parallax Forums
KatyBriKatyBri Posts: 171
edited 2007-09-27 13:56 in General Discussion
Hello,
Does anyone know of a good .com source (ad good price) for dry ferric chloride powder (to be diluted with water to make PCB etchant solution)?
  • RDL2004RDL2004 Posts: 2,554
    edited 2007-09-26 01:33
    Most places sell it already in solution, but I know All Electronics and Ocean State Electronics have the dry form (branded Datak).
    If you are in the US, I would just recommend trying a local Radio Shack, they sell the solution in pint bottles for about $5 which is a reasonable price and very convenient if you're not doing a lot of boards.
    You might try chemical supply places and also look into ammonium persulphate.
    www.allelectronics.com/cgi-bin/item/ER-3/445/DRY_CONCENTRATED_ETCHANT_.html
    - Rick
  • KatyBriKatyBri Posts: 171
    edited 2007-09-26 02:23
    I'm not familiar with ammonium persulphate. What's the story with it?
    edited 2007-09-26 02:33
    Its just another common etchant. It's more likely to be found online as a dry chemical instead of in solution because once dissolved it doesn't have as good a shelf life as ferric chloride.
    www.mgchemicals.com/products/410.html
    - Rick
  • pwillardpwillard Posts: 321
    edited 2007-09-26 17:29
    I know I'm dredging up an old discussion by mentioning this... but I home brew my own etchant from common materials. I get Hyrdogen Peroxide solution from the local pharmacy and a jug of Muriatic Acid from the local Home Supply like Lowes or Home Depot but you can also get it from a swimming pool supply store.
    See http://www.fullnet.com/~tomg/gooteepc.htm for more info.
    There's nothing like a new idea and a warm soldering iron.
  • Blackbird455Blackbird455 Posts: 124
    http://forums.parallax.com/forums/default.aspx?f=15&m=208075 A true gem of a thread.............. Read my last post, shows how very economical and readily available this stuff is !!!!
    Not to mention all of the other good info in this thread.
    Noli nothis permittere te terere
