n-MOSFET NTE2376
Hello,
I am trying to drive a NTE2376 N–Ch MOSFET with a propeller.
And have had little success. There Are 2 separate power rails, the prop at 3.2, and the MOSFET at around 12. I have done a lot of digging online and not been able to find much, most related directly to an h-bridge, for motor control. Any thoughts on at least a good place to look.
Tom
Tom
So Something like Fairchild Semiconductor FOD3181 should work to drive the n-MOSFET?. I could not find any docs or sales info on Micrel, or MIC4400.
Tom
Edit: The point of using the 754410 to drive MOSFETs is you get logic inputs, while the outputs of the 754410 can be connected to 12 volts to drive the MOSFETs all the way. Also, you really do want a limiting resistor in the gate circuit. Driving the MOSFET gate too hard (without a resistor) can actually make it switch the load so sharply that you get spikes on your power supply.
And Mike & Phil.
I just ordered some of the Texas Instruments 754410 and will give them a try.
Tom
····www.micrel.com/page.do?page=product-info/mosfets.shtml
They're optimized for capacitive loads, which is what a MOSFET presents.
*Peter*
