new propeller starter kit
Hi all,
I have got my propeller starter kit two weeks ago. Finally, I have time to test it out. I ran some test sample code and found the out put LED's would turned on as pairs.· (Such as I just turn on the P18 nothing else,·when the P18 turned on and P19 turned on also, but it was dimmer than P18.) Likewise, if I turned on the P19 and P18 turned on with half the brightness as P18. P20 and P21, P22 and P23 are the same as I discripted as P18 and P19. P16 and P17 worked fine. Do I have a leaky Propeller chip? Please advise. Thanks.
Hai
Hai
Take a look at www.parallax.com/dl/docs/prod/prop/PropDemoDschem.pdf
You'll find that some of the lines you mentioned are connected with resistors between.
Oldbitcollector
Buttons . . . check. Dials . . . check. Switches . . . check. Little colored lights . . . check.
— Calvin, of 'Calvin and Hobbes.
Don't know this for sure,as built mine from scratch,but you've got the
VGA resistor divisor on these pins,hence the slightly glowing LED
Regards :- Ian
:- In Scotland we have a word for Sushi :- Bait
Brian
uController.com - home of SpinStudio
Best Regards to you all
Hai
