Prop Education kit Breadboard / using pins 29-31
··· I am interested in adding an additional "permanent" circuit to the PEK breadboard
· by adding 8 switches and 8 LEDs to the right of the prop chip.
· using prop chip pins 24-31 as a 8-bit input switch port
·················and pins 16-23 as a 8-bit LED out port
····························· OR
······················pins 24-31 as a 8-bit LED out port
················and pins 16-23 as a 8-bit input switch port
··· My plan is to use the input pushbutton switch circuit and LED out circuit as used in the
· PEK lab·material.
··· Pins 0-7 and 8-15 are for add-on circuits.
··· What I am wondering is which circuit will provide the least conflicts to the Prop chip pins 28-29 which
··is used with 24LC256 EEPROM & pins 30-31 for the Prop Plug.
··· Thanks for any help.
· PEK lab·material.
Oldbit
Buttons . . . check. Dials . . . check. Switches . . . check. Little colored lights . . . check.
— Calvin, of 'Calvin and Hobbes.
That would certainly work if he wants to do the switching manually.
deSilva,
It sounds like he wants to use DIP switches which would be set all the time, again not suitable without buffering.
You still can get a copy <$10 on ebay.· Be sure it isn't the later versions which modernized the interface into something worthless.
ps, most of the schematic was from the setup lab pdf.
as I had planned on.
What I want to say: With a raw power of 1.000 mcd you can easily reduce current to 1mA and the LEDs are still brighter than the garden variety! 1V/1mA = 1 k
Edit: Killed some typos..
Post Edited (deSilva) : 9/26/2007 10:55:40 PM GMT
