I am tieing into a low voltage signal that signals an igniter to fire a spark plug. Checking with an o-scope is fine, running it right into a pin on the propeller causes that plug not to fire and the engine misses.
Putting a resistor on the propeller pin will limit the current to protect the pin and also cause it not to ground out the signal. 10K or something like that.
You may have damaged the propeller pin if the ECU outputs 12V.
Bean.
I know what I know, don't confuse me with the facts...
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - www.hittconsulting.com ·
I posted this sketch from some of my tutorials some time ago... here it is again. It was drawn to fight some phantastic misconceptions about a CMOS input
ECU
ignitor
····PROPELLER INPUT
Bean.
