Lm338k
I built a power supply using this regulator to power 4.53 amps worth of vacuum tube filaments at 6.3 volts. I set up the supply and ran 12 volts into the input. It gets too hot even with a very large heatsink. I have solved this problem by putting less input voltage into the regulator. The question is, in this case, what is the minimum voltage I am able to put into the LM338K to get 6.3 volts under load.
Note, with the supplies I have I was only able to test it with a 1.8 amp load.
- Rick
I never considered that Filaments needed a strong regulated DC·supply.· Technically, a high current 6V Transformer creating AC to the filaments is all that is required. Are these filaments special?
There's nothing like a new idea and a warm soldering iron.
- Rick
Maybe you can get an idea of what you need from the link above. You can buy Aavid heat sinks at Mouser.
- Rick
