Wind speed indacator — Parallax Forums
riverdanriverdan Posts: 21
edited 2007-09-26 19:48 in BASIC Stamp
I have a small servo motor I am using to check the wind speed. Most of the time it generators 0 to 15vdc I am using a voltage divider to make it 5vdc at 15vdc. I need a bs2 code "analog" to make the 5vdc linear with the 15vdc. I would like to then plot it on StampPlot 3. I just can not seem to work out the math on my own, I need to get pointed in the right direction.
Thank You for Your Time
Riverdan
  • TechnoRobboTechnoRobbo Posts: 323
    edited 2007-09-23 22:51
    multiply by 3 - but it seems thatyour final result should be windspeed.
    Have Fun
    TR
  • D FaustD Faust Posts: 608
    edited 2007-09-23 23:20
    If you are measuring the voltage out of the motor, then I think that it doesn't have a linear response to the speed.· You would have to come up with a convertion formula or something.· I would divide the voltage by four just in case the output goes over 15V you don't want to fry the stamp.
    LOOKDOWN ThisThread, [noparse][[/noparse]Your_?, My_?, Cool_Thing], looknum
    LOOKUP looknum, [noparse][[/noparse]1, 2, 3], subnum
    ON subnum GOTO Hope_this_helps, Thanks!, WOW!!
    END
    edited 2007-09-24 01:28
    The easiest way to calibrate an anemometer is to mount it to the roof of your car. Then, on a calm day, find a nice straight stretch of empty country road, and drive back and forth at 5mph increments, recording each reading as you go. It's best to have a helper do the recording, so you can concentrate on the road and on keeping a fixed speed. When you're finished, you'll have a table you can graph, which will make any nonlinearities obvious.
    edited 2007-09-24 01:36
    Where are you reading the 5 volts? 8 bit Ato D - 12 bit A to D? PWM comparison? What value equls 5 volt?
    Have Fun
    TR
  • riverdanriverdan Posts: 21
    edited 2007-09-24 14:02
    I realy want to thank you one and all for your timely input. Simply put I just need a bs2 code, and or macro, to plot 0 to 5vdc analog in stamp plot "analog" maybe it is in the macro.
    Thanks Riverdan
    edited 2007-09-24 22:25
    What everyone is saying is the stamp needs to convert the analog voltage to a digital form inorder to output something to the stamp plot program. This you have not told us about yet, please do.
    - Stephen
    edited 2007-09-25 04:54
    How "noisy" is the motor?· Instead of looking at voltage, you could actually measure the voltage ripple to get a true RPM of the motor-acting-as-a-generator at least.
    If you’re just interested in wind speed, it might be worth lobotomizing one of the coils on the motor, as this would b much easier to differentiate than a small ripple.
    Beau Schwabe
    IC Layout Engineer
  • steve_bsteve_b Posts: 1,563
    I'd suggest using a gps to get proper speed.
    After I put on 30"tires on my Jeep (They came with 27" tires) I found, with a gps, that my spedometer and gps were saying the same thing.
    So your spedometer might not be as accurate as you think....
    Phil Pilgrim (PhiPi) said...
    <FONT>Steve
    What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
    Lee Travino after the second time being hit by lightning!
