Display a value on a LCD
Hi there,
I am setting up a small device to count how many people enter a room. For this I have connected:
Stamp 1 Project board
LCD Terminal AppMod
One Ping Sensor conencted to Pin 7,
I have got most of it working, so that the sensor counts every other person entering og leaving the room ( assuming that anybody who enters will also exits.
I Total the amount in a Byte variable , Counter, and then display the figure on the LCD, and here is my problem.
How do I convert the value 1234 to Ascii $31 $32 $33 $34
I wrote the following rutine but it only works for values <100
·char = LcdLine2 + 2························ ' show on 2nd line
· GOSUB LCD_Command···················· ' sub to·display the character on the LCD
· char = counter/1000· +$30
· GOSUB LCD_Write_Char·················· 'sub to·display the character on the LCD
· char = counter/100· + $30
· char = counter/10· + $30··············· ' This is the problem!!
· char = counter//10· + $30
The problem arises· with a value >100· e.g. the value 123
First character will be $31 but the second will be $c +$30 and the third will be ok $33
So I have to write another expression, but it must be SHORT since this is BS1 and memory is almost full,
any ideas?
TIA
Peter
LCD Terminal AppMod
any ideas?
TIA
Peter
char = (counter/10) // 10 + $30
You'll need to do something similar with the 100's digit as it'll have the same problem when you go above 1000. Of course, you can't go above 255 currently if your counter variable is a BYTE. It'll need to be a WORD (value 0-65535).
That did the trick. And yes you are right - the Variable is word length.
I'll be back with more questions shortly
Thanks Again
