Debugger question
I am having trouble with the debugger.
The debugger will not set a breakpoint in a line of code that is inside a method other than main. I attached a sample program in which I cannot set a breakpoint in the line that contains the System.out.println that is inside the “called” method.
HELP!
HELP!
java
349B
but perhaps the method Called() must
be declared static as well.
regards peter
Enrique
