Max 1270 & ADC 0838
Greetings all.
I am battling to find a good example to read all 8 channels from the Max 1270.
Please can someone help me with an example.
Question: Will the max 1270 have a better stability reading if compared against the ADC 0838? I have experimented with the 0838 and have a lot of problems with readings. Adding volts to one or more channels sometimes have effects on another channel. This is nun-sequential or what i refer to as nun stable.
Have any one used an 0838 in a large circuit, sampling all 8 channels with success. I would like to see such a circuit.
The max is also sold by Parallax and are recommended for the Parallax PLC.
Any help!!!
http://www.parallax.com/dl/docs/cols/nv/vol5/col/nv105.pdf
Post Edited (Chris Savage (Parallax)) : 9/27/2007 2:34:08 PM GMT
Thanks for the link.
In my last effort to solve my problem i have redesigned my board fitting a LTC1298. I had problems with this IC as well. All 3 chips 0838,1270 and the 1298 all gave me problems with unstable fluctuations on the channels. From your link i have found a added small diagram to reduce noise. My board still fitted with the LTC1298 i have added this noise filtering diagram and it helped, this stopped the fluctuations. My guess is that this will solve my problem on the 0838 and 1270 chips, am i correct? My problem seems to be noise interference. Can one work from a few basic rules when designing boards? Are added noise filters always needed on A to D converters?
I do not have the necessary knowledge to understand what is wrong in my board designs when it comes to A to D converters.
Please can you give me a few tips?
For in much wisdom is much grief, and he who increases knowledge increases sorrow." ~Ecclesiastes 1:18
