Having problem downloading program
I am using a·Parallax Education Board and the microP used is BS2sx. The board interface is a 9 pin serial. I have purchased a 'Serial to USB' convertor as my laptop does not have a serial port. However, after following the step by step instruction guide, i always got a message "No Basic Stamp found" when i tried to download my program.·I am not sure where the problem lies in and also have doubt whether i am using a correct 'straight through' cable. Can someone pls advice me on this problem and also provide me with a internal connection circuit for the straight through cable. Thanks
2) The Stamp has to have power to be identified. Are you sure the power is on?
3) The cable has to connect pins 2 through 7 from one end to the other (see page 28 of the Basic Stamp manual).
1) I have tried using 4 different serial to USB converter. 3 of them are integrated with one end a USB port and the other end a serial port. One of the cable is ATEN (model: UC-232A), the other one is MCT (model: U232-P9) and the last cable is a cable that comes with another set of basic stamp(which model of stamp is unknown) that another group of students is using. All the 3 cables was passed to me without installation CD. However, I have allowed the installation wizard to search the web automatically for the driver. The installation always ends with the message that the new hardware was installled and ready to be used.
I have also tried using a USB-RS232 convertor from Wiretek with installation CD but still fail.
2) Yes. I am sure the power is ON when i tried to indentify.
3) I will be working on it once I am back in the workshop.
Some doubts that I am having:
1)Could it be possible that i have installed the wrong version of the Stamp Editor or rather the wrong compatible items from the parallex? I am using the Education Board and I can see clearly that the microproccessr chip have a "BS2sx" printed on it. Therefore I have installed the editor for BS2sx on my computer(software->BASIC Stamps->windows95/98/NT4->Stamp2/2e/2sx/2p(Stampw.exe)). My OS is however XP Pro.
2) What should I see when I click on 'Identify' if the connection is correct? Currently I am seeing this:
My only personal experience has been with the devices sold by Parallax, with those made by FTDI and sold by several vendors, and with the Keyspan High Speed USB to serial adapter. All of them work fine under both the Mac OS and Windows XP with both the Stamps and the Propeller.
I wouldn't expect the DOS version of the Stamp Editor to work with a USB to serial adapter on anything other than the COM1 and COM2 ports.
