About to cry!!
matb_uk
Hello
I've been pulling my hair out over the last few days trying to software debounce a switch. I've had my Prop for about two weeks now and i've got it hooked up to a HD44780 screen, a couple of LED's and a single solitary extremely annoying switch!
I had similar problems with debouncing on a PIC chip so i expect i should just try to make projects that don't involve any user input!!
Anyhoo, i've taken a gander on the internet and found a couple of approaches one of which is to count while the switch is pressed and reset when not and if the counter reaches some safe value then i can say that the button is pressed. I've tried this and it sorta works except i get a delay after releasing the button before my button flag returns to 0. I've also noticed when tying an LED to this button 1/0 event that it flickers a bit before finally going out which suggests that bouncing is still occurring.
I am using ina[noparse][[/noparse]pin] to read the switch and the switch itself is connected to +3v. Is this correct or am i going about it backwards?
Any help appreciated.
2) There will always be some bounce in any mechanical switch. A simple way to debounce a switch is to look for the off-on transition (ina[noparse][[/noparse]pin] was zero earlier, now it's one). Wait for a reasonable debounce time (maybe 50ms), then check to make sure the switch is still closed. If not, then ignore the whole thing. The same thing happens to a lesser extent when the switch is released.
The switch is connected so it pulls the input pin to ground.
sorry its not as pretty as some people's ascii schematics.
-Chad
I suspect your main problem is not having a pull up resistor, it can cause a lot of confusing problems.
Graham
I haven't had that kind of "bug" yet, but it certainly could happen. Better put a series current limiting resistor in there just to be safe.
- Chad
("Or to ground for that matter. If there's a bug in your program and you set up that I/O pin as an output, it will be grounded and you'll have a short circuit if the switch is closed.")
By default, the Propeller pins are set up as inputs and, if changed to output, the level is low (ground). The same bug could set the level to high (3.3V). Chad's example would also potentially cause a short circuit. It's almost always helpful to use a series resistor like 220 ohm on any Propeller pin that could be connected to another output or power supply voltage, particularly when you're debugging a program. Fortunately, if you're pretty sure of your code or it's a production system or there's some specific reason why a series resistor will cause problems, you can rest easier knowing that it's hard to damage a Propeller I/O pin structure.
I personally would NOT use an additional serial resistor in this context...
That's not fair! There are always circumstances where external hardware may be cheaper, more efficient, more reliable, etc. than doing it all in software just as there are circumstances where it's cheaper, more efficient, and more reliable to do it all in software. For example, the Propeller does not have Schmitt Trigger type inputs. If you truly have slowly changing inputs, it's much better to handle the signal conditioning in hardware than trying to imperfectly approximate it in software. If you're short of I/O pins, it may be simpler and cheaper to use a cross coupled NAND gate with a SPDT switch for debouncing rather than tie up two I/O pins per switch or use some kind of serial shift register for input expansion.
Ken
The more I know, the more I know I don't know.· Is this what they call Wisdom?
You are right - I am unfair, and your counter examples are well chosen. However I am a SW man - and I have learnt a little bit hardware 20 years ago just to become able to convince my EE-colleagues that they need only half of the hardware they deemed necessary
I think we have discussed debouncing many times....
Fact is, there is no need at all to have a "clean" signal from a switch in the first place. So let it bounce!
What you need in software is some intelligence (6 to 12 aditional instructions). True, there can be situations where this is not possible...
What is "bouncing" viewed as signal behaviour? It is a train of pulses (0.1 to 100 ms) before the signal becomes stable during a CLOSING action.
What is software debouncing assumed to do:
(1) Asume the switch is closed during this debounce-time
(2) There is no second...
I did not check the following code, I used a similar piece some monthes ago, but for multiple switches, which looks too confusing...
After looking at this code for 10 minutes now, I think the swDebounceCnt flag is not really necessary, as when you do not call this routine within 20 seconds it will not work reliably anyhow...
The Problem with this second version is, swDebounceCnt must be preset correctly (CNT-swDebounceConst) rather than to 0... this is awkward....
Post Edited (deSilva) : 9/22/2007 7:47:44 PM GMT
As usual I agree with all of you, but for a quick and ( dirty? ) fix go
with the hardware, then when its running do the software fix.
Sorry to all ( ex hardware engineer )
Yes Da Silva great S/W solution but does he need it
if you're trying to unroll a tight loop and constrained by CPU time
you don't need to be waisting time looping on a pin state.???
Best Regards
Ian :- If it aint broke don't fix it
JUST NOTICED I GOT DeSilva's handle wrong
Many Apologies
Best To All
Ian
I never used the HW version, but the software one, in the case of the propeller, can be done with a separate COG, and some waitcnt to put it to sleep between counts, besides being waked up by waitpeq or waitpne.
www.ganssle.com/debouncing.pdf
David
Hereby a cool link to a interesting document re deboucing swithces
http://www.ganssle.com/debouncing.pdf
Well worth downloading and having a good read.
Cheers
Ronald Nollet·· Australia
thanks for the link
Graham
All "real time" processing is a matter of "need to know". We generally tend "to be prepared" for situations that rarely will happen and being much too fast (in engineering i.e., not in politics )
So when you need to react IMMEDIATELY to a button press, then use a COG (has nothing to do with debouncing in the forst place)
But generally "polling" will do.. So what happens when you just start in a gap during the bouncing? You will not "see" the press. But you won't do either when you load one of those little caps generally proposed
The reason behind debouncing is that you not unintentionally mistake a "gap" for a "release".
My very small (!) SW solution is handicapped by the fact that CNT "aliases" after 40 (I think 40, not 20..) seconds. this will most likely be no problem at all.
When talking of the use of an independant COG, then a "General Timer Action" would be nice (e.g. resetting a regsietered HUB cell after a defined time less or MUCH larger than 40 seconds).
This is one of the ideas behind a "Small Utility COG" (SMUC) I haven't tracked further during the last monthes :-(
Best Regards Ian.
The circuit relies upon the capacitor being charged via the resistor which means the I/O has to become a high output long enough to charge the capacitor and then it can release the I/O line (become an input). The self-discharge of the cap is relatively slow so that if the prop checks the I/O pin as an input it should be high. If it is high it can optionally refresh the charge on the cap. If it is low then it means the button has been pressed since the last check as the button discharges the cap and there is nothing to recharge it as the 10K is not sourcing current.
You may find if you don't refresh the charge that it may actually hold the charge for several seconds or more.
The 10K resistor can just as easily be a 100R resistor, it really doesn't matter. The lower value will charge the cap faster, the higher value will perhaps protect the input a bit more from ESD (as does the cap).
As I have said previously, this circuit is super-simple yet very reliable and can be handled easily even by slow-polling software.
What does everyone think?
*Peter*
Peter also handles debouncing, but in the first place he addresses "missing presses" which is quite another issue.
A 1k will generate a latency of 100ms - you can press faster; 1k will be best, but I should rather reduce the cap, as 0,1u is a lot of charge - discharged abruptly.
Attention: The idea to place the other end of the press button directly at the I/O rather than between cap and resistor is not so good, as it would lead to a short when you press the key whilst the circuit is charging..
BTW: My personal philosophy is to do in hardware what can't be done in software and not do in software what cannot easily be done in hardware But also to know both worlds!
Post Edited (deSilva) : 9/29/2007 6:55:44 AM GMT
As to sensing multiple key presses that is totally up to the software as to how often it will be polled. If you don't poll it often enough then you still know whether it has been pressed or not when you do get around to polling it.
If you want to scan keypads then this is not the usual way to do it, but if you want to sense momentary switch closures this surely is the simple and elegant way.
Any values given are purely for illustration of principal. Personally I would use 0.01uF and 220R which would result in only a microsecond or two of charging.
*Peter*
Steven Kirk Nelson (slamer)
Team K.I.S.S
Build Safe, Build Mean, Build Strong!
