javelin demo board — Parallax Forums
javelin demo board
ichoelichoel Posts: 17
edited 2007-11-13 18:48 in General Discussion
Is it possible if I build my own javelin demo board?
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2007-09-21 03:13
    Yes, you can design a board of your own.
    Just be sure to put a female SUBD9 connector
    on the board for easy programming.
    And don't forget the two 0.1uF capacitors
    on the ATN line.
    regards peter
  • ichoelichoel Posts: 17
    edited 2007-10-02 01:58
    Can i use the schematic on download page?
    edited 2007-10-02 06:03
    Yes you can.
    The required parts to be able to program the javelin are connectors J1 and J2,
    capacitors C3 and C4 and socket U1. If you design an application board,
    I advice to include series resistors of 220 ohm on·all Javelin I/O pins to prevent
    damage to the javelin due to program errors. These resistors will limit
    I/O pin current in case two output pins are connected together.
    regards peter
    edited 2007-11-13 11:51
    can i use javelin stamp module on basic stamp development board? what's the difference of basic stamp board and javelin board?
    edited 2007-11-13 12:14
    Yes you can. The difference is the Javelin Demo Board has a 2nd COM port with
    onboard level shifter TTL-RS232. This was done because the Javelin JIDE port,
    which is used for programming, outputs debug data that contains additional bytes,
    so the programming port cannot be used to talk to serial devices.
    If you used the basic stamp board with basic stamp to talk to such a device
    then you need to add a levelshifter when you use the basic stamp board with a javelin.
    regards peter
  • Robot FreakRobot Freak Posts: 168
    edited 2007-11-13 15:57
    And don't use the USB BoE with small programs.
    It stops functioning.
    edited 2007-11-13 16:23
    Robot Freak,
    That issue has been resolved. See this thread:
    http://forums.parallax.com/showthread.php?p=656527
    If you think you have a small program that proves otherwise,
    please post it and I will test it.
    regards peter
    edited 2007-11-13 18:28
    Peter,
    Yes, I know you solved it.
    But are the new BoE's changed?
    Isn't it a littlebit strange?
    You buy something from Parallax and you have to modify it right away?
    Robot Freak,
    The problem is that there is no design flaw. The issue that causes this is related in part to PC USB latency issues. Some people don’t experience the problem. Those that do can use Peter’s work-around, but since the USB-BOE was designed for the BASIC Stamp it will most likely not be revised due to this one issue. At some future point it may be revisited but even now some BASIC Stamp users have to make software adjustments to the PC USB settings to get communication. Again, not everyone is affected and, at least with the BASIC Stamps, this work-around solves 99% of the communication problems with the BASIC Stamp over the USB connection, but it also serves to point out that the issue isn’t on our hardware. As technology changes we will attempt to adapt as best we can to serve our customers. Take care.
