The BASIC STAMP Stick
I liked the idea of the Prop Stick, the kit form of the Propeller Microcontroller, so I used the same design and created the BASIC STAMP Stick. This allows the BASIC STAMP to be put into different projects through a ZIF socket, or a standard IC socket. I also like this design because not only it can be integrated directly into project ans swapped to other project, it also can be used in a breadboard for development work.
http://www.myspace.com/droidworks
Since it is very handy for protecting the BasicStamps pins for wear and tear, and provides a physically tight programing interface, there is a real need for it.
I was thinking of naming it, 'the Stamp Protector'
Still, the race is won by the swiftest. You got there first. Congradulations.
On mine, I did realign the I/O pin distance to a regular narrow DIP spacing though [noparse][[/noparse].3" less width]. It seems like all the less expensive project boards I solder up do not easily accommodate the wide 24pin DIP.·That allows me to build more cheap prototypes that are solidly soldered.
I also didn't carry through the 4 serial port pins - no reason to do so.
I need to get you some photos to explain better.
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
Post Edited (Kramer) : 9/23/2007 5:35:47 PM GMT
You are welcome to use the name 'Stamp Protector', you can even trademark it if you want. It does get the concept across that the carrier is useful protection.
As I said above, the 0.3 spacing really allows me to use cheaper ready-made single sided boards as they don't support 0.6 devices very well. The wires need to be run under the DIP socket to reach the I/O - nearly impossible.
I do find the ZIF socket nearly useless. It is quite bulky. The only real need for having one is if you want to test or program a lot of BasicStamps and that might only happen if you are teaching a class of 20 students.
I have a 24pin ZIF that sits on a similar adapter for exactly that purpose, but I rarely use it.
Post Edited (Kramer) : 10/17/2007 8:36:34 AM GMT
--DFaust
good work, great design, I love it.
