Does somebody have a sample code to send to another IP address.· I know the specific code I need for the· device, but I do not know how to call another IP address.
When I ordered the module I thought I was getting a pink lady module, but I got a SB70 board.· I am looking for some sample code to send serial strings to another IP address.
Let’s try to get on the same page as I feel there may be some confusion and misunderstanding here. The difference between an SB70 from NetBurner and a PINK Module from Parallax is the firmware. The PINK is an SB70 pre-loaded with out firmware. You will know if you have a PINK Module as when you go to the configuration or factory web pages you will see the Parallax Logo. If you have that then you have a PINK Module and our documentation and code applies.
Some time ago in another thread the OP was asked to clarify if the module was a PINK or blank SB70 with no response. This thread is asking for code help while the other thread indicated the unit was not working. I am assuming this thread indicates this module is working and is probably a PINK Module but until we have clarification we can’t do much more.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support
Dave
Dave Andreae
Parallax Tech Support·
Dave
Dave Andreae
Dave
Dave Andreae
