water flow detection, on filling up small waterfall
Capdiamont
I have a small desktop waterfall, that the cats 3-4 love to drink out of. This drains it pretty fast. My idea is to build a stand for it, with a hidden 5 gallon plastic bucket in the base, and a catch basin under the waterfall which drains in to the bucket. I'm thinking of using a sx, to turn on a pump in the bucket to fill up the waterfall once in a while. I intend to have a button for a user to indicate for the pump to turn on now, and some way to detect when the waterfall is overflowing, and thus full. That is my hard part is the overfilling detection. One idea is a trapdoor underneath the drain, weighted so any weight, water will push it down, and trip a sensor/switch. Others is exposed contacts, or weight of the waterfall. The delay between when the pump is turned on, and it is full will also be used to adjust the interval between pumping. IE, short time to fill it, lengthen the time between fills, and longer time to fill it, shorten the time between fills. I would like to store this in some sort of eprom/flash memory in case of power outage. Since I want the sx for cost, I think this might mean external to the sx storage. Might be good to have a temp/humidity sensor and vary time intervals based on that, more storage/look up tables.
Microswitches come in many sizes, many voltage ratings, and with many different lever arms. Some are designed for all-weather use.
If a BasicStamp is involved, the low voltage saves you a lot of money as the lower voltage microswitches are both smaller and cheaper. Use a length of piano wire with a float on the end to distance the switch from the water. I imagine just a wine cork would be a handy float.
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
The QT114 from QPROX is a nice water level detection chip based on capacitance.
Tracy Allen
www.emesystems.com
- Stephen
I think this sight explains how to use a plastic tube, copper conductors and RCTime to measure water height.
1. Connect the tube to the bottom of and run it up the side of the container. Leave the tube open.
2. Run 2 copper wires up the outside of the tube to form a capacitor. As the tube fills with water, the capacitance will change.
3. Use RCtime and a full and empty container to set your limits and develop your code.
You can even set limits for an alarm.
SJW
I was unable to read any of your PDF files as well. Any thoughts?
Shawn Lowe
Maybe I should have waited to do that......
Applied Sensors Parts and Text, v1.4
Tracy Allen
www.emesystems.com
All the Parallax documents that I have reviewed make reference to an emersion probe. Perhaps I missed one.
I like the capacitive approach because nothing comes in contact with the water.
You can heat shrink the wires and or copper foil in place.
SJW
You can integrate the sensor in any fill / flow / drain tube you like.
Check out the closed loop control systems examples posted on the Parallax web sight. Process Control. http://www.parallax.com/detail.asp?product_id=28176
Good luck.
SJW
There's nothing like a new idea and a warm soldering iron.
If the drain is a normal bath tub size, will the small flow be detectable?
Well you have come full circle. A good robotic microcontroller design can only be as good as the mechanics of the device. You need to balance tubing size, pump size, drain size, and reserve before you can expect the BasicStamp to be able to fine tune things. Flow rate and pressure are directly involved.
One trick to to put oversized tubing on the resupply, the·input and the output, but have valves than can restrictively tweak the flow to an optimal balance.
If you need fluid flow literature, there is material that originates out the the P.E. license program in the U.S. The Intern Engineer Certificate material is quite useful. I happened to have long ago passed·a Califorina Professional Engineer's Certificate as an E.I.T. [noparse][[/noparse]the old name 'Engineer-in-Training' or nowadays, Intern Engineer]; so I see the broader picture of the problem.
But be forwarned, engineers create a number for everything. One has to do the math to get the results.
In sum, the primary system is fluid flow; the control system is a secondary system. You could just as easily use a mechanical secondary system, though using a microprocessor and electronic control is an equally valid choice. But, if the primary system ain't right, nothing's right.
Because it is a 'water fall' I suspect that you really don't want more pressure involved.· Gravity feed whenever possible and larger tubing will keep you from have water 'squirt' unexpectedly.· The drain need not be huge, but balanced within the context of how much the pump can handle.· If you don't have specs, you have to run tests, just like a real engineer, to get useful data.
Post Edited (Kramer) : 9/28/2007 8:24:13 AM GMT
I'm thinking that SS rods, won't dry out enough in this application, and light method may not be tripped if too large of a drain.
I hope this helps.
http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv27.pdf
SJW
There are tiny microswitches that response to a feather-light touch. By all means, go ahead and try to research all the possibliities. But either a mercury switch or microswitch as a float device is likely to be most reliable.
High tech cannot always find a way to replace low tech. Many solutions are brilliantly simple.
There are other kinds of instruments that measure both the real (ohmic) and the imaginary (capacitive) parts of the dielectric constant, to get at conductivity and concentration of ions.
edit: pH7, not p7
Tracy Allen
www.emesystems.com
Post Edited (Tracy Allen) : 9/28/2007 8:32:19 PM GMT
I recommended capacitive sensor for this application because nothing comes in contact with the water.
I have been discussing how to measure/control the height/flow rate of steam distilled water in a decorative consumer fountain that the cat(s) drink from using a home made sensor and uncelebrated units of PULSIN/RCTIME/POT.
The control system as a hole can be calibrated againest a full and·empty fountain with limits set by the user.
SJW
Shawn Lowe
looking over the design, I'm wondering why the N&V didn't measure the capacitance directly with rc time. Why not use a 555 chip? Basically I don't have a 4060 chip.
