stupid photoresistor question
I know this is dumb and very elementary but..
Is there a simple way to set a pin high with a photoresistor without resorting to adding a capacitor and using rctime?
I'm basically using a white led and the photoresistor to isolate an industrial 17vdc sensor.
It works using the aforementioned rctime and just checking if time < 50, but it's a slow response and seems like it shouldn't be necessary.
I attached the quick sketch of what I was trying (that obviously doesn't work).
The photoresistor value changes between 13Kohm to 350ohm when active. What's the simplest way to detect this?
The aim is to have the junction of your voltage divider at logic level 0 in a dark condition ( between 1v and 1.2v should be good ) and as the light falls on the photoresistor the voltage at the junction of the divider will rise to logic level 1.
Divider voltage = R2/R1+R2 * V
Jeff T.
Do you have to see the white LED as well?
Use a photo transistor.
Photoresistors are inherently slow. A photo transistor is fast.
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
I just got it working 2 seconds ago and it seems to be working good, though the response isn't great. The response is probably being held down by the debug calls though. Just gotta tweak a little.
Thanks!
Works with TV remotes too.
Have Fun
TR
