Control panel Access
Jim, for some reason I can not access the Control Panel - I hope you can help.
If I go to the forum and click on Control Panel, the screen goes to a blank forum page, the blue bar in the lower left hand corner slowly fills and eventually I get the Control Panel Home page.· If I click on Edit Subscriptions, Edit Subscriptions turns red, and the computer freezes.· If I hit Ctrl+Alt+Delete, the Task Manager tells me AOL is not responding.
Any suggestions?
Sid Weaver
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
Any suggestions?
Sid Weaver
Don't have VGA?
Newzed@aol.com
I'm not sure which browser you are using, but what you describe sure sounds like something gummed up on your PC. There isn't a way to get the browser to do what you describe without some elaborate JaveScript or something on your machine is using a lot of resources. My first guess is that the machine is running out of available memory. You can verify that with the Task Manager. Select the Performance tab and look at the amount of physical memory Cached and Free. These should be at least 15-20 percent of total memory.
If you are using Internet Explorer, try loading Firefox and use that to browse the forums (fora for the gramatically expiedient). The idea is to use a different browser than you normally use to see if the issue is browser related.
Jim
Jim
Parallax IT Dept.
According to the Performance tab:
Physical· 392Mb
Available· 114Mb
Cache···· 228Mb
I have downloaded Microsoft IE7 but have not yet installed it.· Should I?
Sid
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
Jim
Parallax IT Dept.
