SuperMill makes a Miniboard!
After numerous attempts, I finally figured out a way to register a board so I could do the top half, move the board and do the bottom half.· A photo of the Miniboard, which measures 4.000 x 2.500 is attached.· Remember, the capacity of SuperMill is 1.700 top to bottom.
I etched and drilled the top half, then moved the board and etched and drilled the bottom half.· The top row of holes for the 40-pin Prop DIP were done in the top half, the bottom row of holes in the bottom half.· The 40-pin DIP socket, the PS/2 connector and the DB15 connector all dropped right in.· There is s small glitch in the etching - I found it yesterday on the first attempt.··I corrected the error and sent the corrected program to the Shop, but when I went out to make another board this morning I forgot to load the corrected program, so the glitch was still there.· With that in mind, I went ahead and finished the board so I could post a picture.
Making a board like this is a bit of work, and I probably wouldn't do it unless there was no other way, but now I know I can do it if necessary.
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
You are realy getting Very good at making these boards with your· SuperMill
Very very nice board keep up the good work
··Thanks for any·
Sam
Are you pushing the trace width limit or can you push it further?
It's barely wider than the router bit.
- - - PLJack - - -
Perfection in design is not achieved when there is nothing left to add.
It is achieved when there is nothing left to take away.
http://forums.parallax.com/showthread.php?p=674624
Sid
Don't have VGA?
Newzed@aol.com
When are you going to get your SuperMill?????
Sid
Don't have VGA?
Newzed@aol.com
It is definitely a real useful adjunct to this hobby. I just don't have the tools and space to commit to creating my own.
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
If you ever decide you want to build one of your own, I'll be more than happy to help you anyway I can.· There used to be a very active thread, "Community Milling Machine", or something like that, but it seems to sort of have died.
Sid
Don't have VGA?
Newzed@aol.com
The Super Mill is likely to forever hold the Parallax record for the longest forum thread. A remarkable creative collaboration.
My problem is that I live in Taiwan and procurement of parts is an odessey. For instance, I have a universal programible IR Remote Control on my desk that I bought for $3.00. But it took about 10 hours to translate the instructions to program it from Chinese. It isn't that I'm stupid. Looking up Chinese characters one by one is just slow regardless of your method for doing so. ABC has 26 letters and Chinese has 7000 of these characters.
I did see an XYZ table in Nuts and Volts for $3000USD plus shipping. All I would have to do is add a router and provide the intelligence. My guess is you got yours for about $500.
http://www.productiveworkspace.com/detail.aspx?ID=93
Sid
Don't have VGA?
Newzed@aol.com
