BS2 Board of Education
So i bought the usb to serial converter and install it and everything. Not sure if it's right or not, then i follow the book through all those step and stuck at where it say "The green light labeled Pwr on the Board of Education should now be on" I went into BS2 and do that identify stuff and it showed up only the Loopback and Echo (saying yes); however, there were no device name or version?! What is the problem? Im sure my batteries are new, no so sure if i install the USB to SERIAL right, and prettyyy sure the board is not broken because its pretty new.
- Rick
Post Edited (RDL2004) : 9/19/2007 11:10:53 AM GMT
Green means : power is on. So it looks like there is something wrong with your batteries ... switch is in position 1 or 2 I hope !?
Ed
- Rick
Ed
When that happens, one usually takes out one's volt-meter, and WHILE CONNECTED TO THE BOE measures the voltage at the battery. If it's below 6 volts, there's your problem.
Making SURE of power is usually the first step in most trouble-shooting procedures.
