PENGUIN ROBOT Remote Controller - the Code is Here!
This is a new master drop in code to enable use
of a Parallax hand held remote controller for
a Penguin robot program.
Anytime you want to add the hand held remote
function to your program, this is the code to use.
humanoido
penguin_remote_controller.bpx
humanoido
humanoido said...
USING THE REMOTE
This is so simple. With the remote, just point and press. The
name of the key pressed will appear on the debug screen. It's
a simple matter to replace the code subroutines with your own
Penguin robot functions!
' This program can also be used to determine the IR range, determine ' which keys equal which code, confirm the operation of SONY ' standard remotes, confirm the operation of Penguins' infrared ' receiver, adjust the infrared receiver, test bank switching ' in remotes, troubleshoot off brand remotes, check the functions ' of a Parallax remote, confirm remote battery conditions and add ' remote function to your own Penguin robot programs.
Man! you can realy write comments.
When I was an engineer, I never liked wrighting coments becus I was afrade uv misspilling sumthing.
So I became a pro bicycle racer, learned french, and now I have an excuse!
Many thanks you for your generous contributions!!
I guess I just was misled by the function's name. It could be just as easily be called Capture-Input-Timing.
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
Post Edited (Kramer) : 9/18/2007 8:11:26 AM GMT
http://forums.parallax.com/showthread.php?p=698975
humanoido
Post Edited (humanoido) : 3/23/2008 4:59:25 PM GMT
If you have the parallax remote, after replacing batteries, it may need resetting. Push and hold the reset button until a steady red LED light appears, then release, and enter in 605 for the SONY code. The LED will go out and the process is complete. You could follow this in the instruction sheet that came with the remote. Now you can test the remote on your Penguin Robot or a SONY TV.
humanoido
LE: problem solved [noparse]:)[/noparse] "SET-UP"="reset" on my remote
Thank you humanoido and keep·up the good work [noparse]:)[/noparse]
Post Edited (twizar) : 4/17/2008 3:56:59 PM GMT
