Keyboard/Mouse question.
RicardoP
Hello!
I've been thinking about this little project and finally I decided to do it. But there are a couple paths that I could take (probably more but anyway ... ) and I would like to get some advice on.
Basically I need keyboard/mouse input, the gotcha is that it needs to be as fast a possible (meaning I don't want much/any delay between the key press and the time the prop does something with it.
Route a)
Use a ps2 hookup directly to the prop, this would probably give fastest response time.
Route b)
Use a pc, read the kb/mouse data and send it to the prop via serial connection.
Route A seems obvious but Route B has a cool advantage ... I can write a nice front end that would allow remapping of the keys (user presses 'W' for example and the program remaps it to some other key)
Thanks!
Route a)
Route b)
Thanks!
Graham
If you wanted / needed to off-load work from a Propeller, you could always use another Propeller instead of a PC. Far cheaper, more 'planet friendly'.
In tests I once did, few perceived a delay between pushing a button and a LED coming on 100mS later. It takes around 20mS for a character received to be shown on a monitor. Serial comms would run far faster than that, so the answer is the delay would not be noticeable.
Post Edited (hippy) : 9/17/2007 11:59:50 PM GMT
This is exactly was PropTerminal does. Try it out to decide if this way is fast enough for you:
http://forums.parallax.com/showthread.php?p=649540
Andy
There 2 versions of the program in the zip file. One uses a PS2 keyboard plugged into the protoboard, the other is serial. I believe those 2 programs should be able to answer your questions.
