Piezoelectric Speaker Substitution in BASIC Stamp Lessons — Parallax Forums
Ol' GeoOl' Geo Posts: 30
edited 2007-10-17 16:32 in BASIC Stamp
Hi, folks...
As I am studying Stamps in Class course, I notice some upcoming lessons would require piezoelectric speaker for experiments. Because of my deafness since infancy, I would not be able to follow the leassons without outside hearing help. I wonder if there is such a substitution for the speaker such as vibrating apparatus, perhaps a piezoelectric vibrator (not sexy one, mind you.) Deaf students would be able to feel vibration instead of listening during the study.
I understand Parralax does not sell such an apparatus. Anyone has a suggestion? Would very much appreciate it.
Thanks.
Ol' Geo
Retired Software Engineer
An oscilloscope is a window of unseen electronic world. - GM
Post Edited (Ol' Geo) : 9/17/2007 4:37:44 AM GMT
    edited 2007-09-17 07:07
    Ol'Geo, the peizo speaker runs off a port from the Basic Stamp.
    The key is discarding the peizo element and working with the port.
    Code can toggle the port high and low, so why not use a blinking
    LED? It may be more easy to see a light than constantly keep
    a finger on a sensor.
    humanoido
  • Ol' GeoOl' Geo Posts: 30
    edited 2007-09-17 17:02
    Thanks, humanoido, for the suggestion. However, I believe feeling has more responsiveness than seeing but I could be wrong. I just need a vibrating device in order to compare with a blinking light. BTW, one company is already marketing a vibrating mouse. I can't use it for the board.
    Geo
    edited 2007-09-17 17:31
    Now don't shoot·me down in flames before I've finished but wouldn't a few iron filings spread on a piece of paper on top of the piezo speaker give a more visual display? the vibration would move the filings around not a magnetic field like with a·normal moving coil·speaker.
  • Beau SchwabeBeau Schwabe Posts: 6,568
    edited 2007-09-17 17:46
    Ol' Geo,
    Having a little background in bio-feedback sensory mechanisms, for most if not all of the lessons, you could use a standard 8 Ohm speaker (size of your choice)...
    To "feel" the frequency you could place your fingers (lightly) on the speaker cone. For higher pitched sounds where the vibration might be too small to distinguish,
    you could feed the speaker a second frequency in a bridge amplifier configuration so that it creates a beat frequency that can be felt.
    i.e. If you are trying to "feel" 2000Hz, combining it with a second frequency of 1900Hz would create a Beat frequency of 100Hz AND 3900Hz... you will be able to
    "feel" the 100Hz much easier than 1900Hz, 2000Hz , or 3900Hz.
    Let me know if this sounds (no pun) applicable, and I will try to put a schematic together for you and others that may benefit.
    Beau Schwabe
    IC Layout Engineer
    edited 2007-09-17 18:38
    Skylight, thanks for another suggestion. It might not be practicable while watching some filling falling off the edge of paper. Anyway, I won't shoot you in the flame. [noparse]:)[/noparse]
    Beau, yours might be more applicable. Yes, I understand what you meant about beats in music. I already studied "What's a Microcontroller" lessons. Big help, indeed. I had an experience with speaker's cone vibrating in the past. The problem is that I ain't no hardware guy but can read schematic. Would very much appreciate if you supply a schematic showing how to "hook up" the magnetic speaker with BASIC Stamp board. I understand the speaker needs more power than the board, correct? If you are interested in knowing about the vibrating mouse that is soon to market, I'll supply the info.
    Ol' Geo
  • N8JGUN8JGU Posts: 1
    edited 2007-09-17 19:00
    Aquire one styroform coffe cup. Place hole in bottom of cup. Glue Pizo Speaker to bottom of coffee cup from behind so the pizo hole is facing up from the bottom of the cup. The cup acts like a cone or parabolic dish. Put hand over open cup. Feel vibrations that were amplified from the cup. Just a low tech idea.
    edited 2007-09-17 19:07
    Not bad idea, N8JGU. Wonder if the cup can be felt well enough. Can try it, tho'.
    Thanks.
    Ol' Geo
    edited 2007-09-17 21:27
    This is the sort of thing I was on about, different patterns caused by different frequencies so you would get a visualization of what the sound frequency was, at least that's the way I read it?
    http://www.collegeofsoundhealing.co.uk/pages/cymatics.html
    edited 2007-09-17 22:14
    Awesome article you supplied the link. Thanks, skylight. Videos of "Cool Salt" are showing many interesting patterns. I am thinking of a simulation of "salt dancing" for PC to view patterns of different frequencies. Too bad I don't have such a formula for the simulation. I am not a sound physicist. Also, Parallax does not sell microphones for feedback when/if I ever develop the simulation. Maybe, some day I will.
    Geo
    PS I could be wrong that Parallax does not sell small mikes for BS boards. Couldn't find them at their website.
    PSS I don't like salt spilling over me. [noparse]:)[/noparse]
    Ol' Geo
    edited 2007-09-18 07:36
    Beau,
    Yikes!
    You apparently negected to mention that the 8ohm speaker CANNOT directly connect to the BasicStamp as it would pull too much current.
    I am setting up a 'one transistor/ one resistor' amplifier to drive a speaker. While it isn't pure audio in the sense that the square waves are not smoothed to sine waves that swing from plus to minus, it is a minimal approach that can be fit onto a breadboard and existing power. {True sine waves require a dual power supply, like +5 and -5 volts}
    "Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
    ···················· Tropically,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
  • TechnoRobboTechnoRobbo Posts: 323
    edited 2007-09-18 09:59
    Can you put a dynamic mic by the Piezo - amplify it through you PC and listen through headphones?
    If you require the visual representation of the sound use this software
    http://www.zeitnitz.de/Christian/Scope/Scope_en.html
    It's a PC sound card oscilloscope - it will let you see the waves coming from the piezo,it's free and will us the same microphone.
    Have Fun
    TR
    Post Edited (TechnoRobbo) : 9/18/2007 10:28:56 AM GMT
    edited 2007-09-18 15:34
    Kramer,
    I was thinking of the method similar to what is described·in the Stamp manual (see attached) for driving a speaker, but I have not had time to do any testing.
             15Ohm +        +         +   15Ohm
    I/O #1 >--/\/\--||---o---||----o---||--/\/\--< I/O #2
                   10uF  |  10uF   |  10uF
                         o SPEAKER o
    I/O #1 - Frequency from Stamp you want to hear
    I/O #2 - Fixed Frequency from 'another' Stamp, 555, etc.
    Note: The Speaker should be approximately 8 Ohms.
    ·There is nothing wrong with using a 1-Transistor amplifier, you might even totem-pole two transistors so that you have two separate inputs.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 9/19/2007 6:59:56 PM GMT
    398 x 212 - 18K
    SPK.JPG 18.3K
  • stephenwagnerstephenwagner Posts: 147
    edited 2007-09-18 16:20
    Ol'Geo
    Substitue the Pizo Speaker with a small pager vibrator, resistor and a small signal NPN transistor. Use a long 3 conductor servo extention wire to connect the circuit to the stamp. The vibrators are cheep and available from Mouser and or Digikey and or Jameco. Choose a 3VDC 80mAmp model. The NPN transistor can be any transistor with a greater then 200mAmp collector current (2 times the motor current to be safe) and a Bata of greater then 25. (80 mAmp / 25 = 3.2 mAmp) The Stamp can supply up to 25 mAmp. Use a base drive resistor between 200 ohm and 1.3K ohm (1300). Closer to 1.3K ohm would be better.
    Stephen Wagner
    edited 2007-09-19 16:47
    Wow! Big thanks to you all, guys. I could have both software and hardware substitution in place of piezo!
    Geo
  • Dave-WDave-W Posts: 94
    edited 2007-10-16 15:22
    Geo,
    Glue the pizo to the bottom of a bowl of water. It should produce acoustic waves in the water. Or, current amplify the stamp signal and drive one of the cheap surplus solenoids glued to one solid piece of wood and the armature glued to a second piece of wood that could be felt by the students fingers.
    Good luck
    D. A. Wreski
    edited 2007-10-16 17:23
    Great idea! Could try that one, too.
    A deaf person could live a better life in the name of Electronics!
    Geo
    Post Edited (Ol' Geo) : 10/16/2007 7:48:28 PM GMT
  • MorrolanMorrolan Posts: 98
    Idea:
    1. Frame
    2. Circular bowl (square would cause wave-bounces and interference patterns from the corners)
    3. 4 Springs (stiff)
    4. Time and effort
    Build a simple, heavy frame with four uprights, one at each corner. Mount the bowl to these uprights using stiff springs to all for some movement. Attached amplified piezo or vibrator to the bottom of the bowl. Fill the bowl with coloured water, and watch those waves dance!
    The springs have to be stiff enough not to woble easily, but stiff enough that the bowl will move slightly when triggered.
    I saw this on TV once, can't remember what it was but they were just touching vibrating objects to the bowl, rather than permanently fixing them together.
    Different coloured food dye works wonders - experiment as different lighting in the room can make different coloured water easier to work with.
    Flying is simple. You just throw yourself at the ground and miss.
    "I think computer viruses should count as life. I think it says something about human nature that the only form of life we have created so far is purely destructive. We've created life in our own image."
    Stephen Hawking
    Post Edited (Morrolan) : 10/17/2007 5:11:31 PM GMT
