Since both devices use the AppMod connector and neither has a pass through, the easiest option I can think of is to connect the CMU-Cam and place the Eb500 somewhere else using pluggable wires to make the connections to the power and I/O pins. This way you can also re-assign the I/O pins used for communication. I hope this helps. Take care.
http://www.parallax.com/detail.asp?product_id=800-00029
