Float32 Log not working as expected — Parallax Forums
BasilBasil Posts: 380
edited 2007-09-18 00:01 in Propeller 1
Hi All,
I have a problem again [noparse]:)[/noparse]
I have the following code:
DAT
        bADC            word 0  'barometric adc data
        bAlt            long 0.0'ft
        bPres           long 0.0 'kpa
        bGroundAlt      long 0.0 'ft
        bPrevAlt        long 0.0 'ft
        bVel            long 0.0'ft/s
        Period          long 200
'Calibration
        PRES_ALT_CONST  long -6.8755856e-6
Pub do_pres_calcs(timechange) | bfADC,ftimechange
  bfADC:=fl.fFloat(bADC)
  ftimechange:=fl.fFloat(timechange)
  'change time from ms to s for calcs
  ftimechange:=fl.fDiv(ftimechange,1000.0)
  bPrevAlt:=bAlt
  'Pressure=((ADC/4096)+0.095)/0.009
  bPres:=fl.fDiv(bfADC,4096.0)
  bPres:=fl.fAdd(bPres,0.095)
  bPres:=fl.fDiv(bPres,0.009)
 'Altitude=(10^(LOG(Pressure/101.325)/5.2558797)-1)/(-6.8755856*(10^-6))
  bAlt:=fl.fDiv(bPres,101.325)
  bAlt:=fl.Log(bAlt)
  bAlt:=fl.fDiv(bAlt,5.2558797)
  bAlt:=fl.Pow(10.0,bAlt)
  bAlt:=fl.fSub(bAlt,1.0)
  bAlt:=fl.fDiv(bAlt,PRES_ALT_CONST) 'alt in feet
There is a bit more after here but nothing that touches bAlt (which is where my problem is)
The code seems to go wrong with bAlt:=fl.Log(bAlt).
Measuring ground pressure, bPres ends up ~102.48 which is correct for where I am.
I have calculated all the steps manually, and in excel
bAlt:=fl.fDiv(bPres,101.325) gives 1.0113989637305699481865284974093
bAlt:=fl.Log(bAlt) gives wild numbers between 0.14 and 0.49, where it should be 0.0049225043228992493572043410264757
Can anyone throw in some suggestions?
Thanks!
-Alec
My our page
    edited 2007-09-16 22:30
    Maybe it wants
    fl.Log10(bAlt)
    instead of
    fl.Log(bAlt) -- base e
    But that would not explain the wildness. ??
    Tracy Allen
    www.emesystems.com
  • BasilBasil Posts: 380
    edited 2007-09-16 22:43
    Hi Tracy,
    Log10 gives similar results (still 0.xx rather than 0.00x).
    The strange thing is, log (base e) works on my calc and also in excel :\
    -Alec
    My our page
    Hi Guys,
    Righty, ive found a linear version of the same math which is ok but not ideal.
    Id prefer not to use it as the log based result (when it works!) is more accurate.
    Does anyone know who wrote Float32? or has anyone used fl.log sucessfully?
    -Alec
    My our page
